How do I connect the favero Assioma DUO to my Garmin Edge 530?
will the 530 “see” the pedals right- left in two different pairings?
You don't need to connect all three of them. Only pair the ANT+ sensor with your Edge 530. Don't use Bluetooth. Generally Bluetooth is inferior and should only ever be used if you have to connect the power…
From the manual:
”Cycle computers with ANT+ technology have to be paired with the left pedal only. The left pedal will transmit the data collected by the corresponding right pedal too.
Cycle computers…
Thanks Gary , I will check this out!
Ty, nradov! :-) It works nicely now. I removed the BT sensors and changed settings in the app to unified channel. Now the left and right pedal chat with one another and the left pedal tells the result to the headpiece. Can't wait for better weather. :-)
