Saves button clicks :) Regards
the problem with this Calibrating promt message that only works if the unit is fully turned off and on, if You put it only to sleep with short power button pushing , it doesnt work, it was an old bug in Edge 1K too, and they couldnt fix it yet somehow (there are other bugs too with "sleep only" function, there is no training status uploading to GC, etc)
Tnx Garmin! Now it is far better. Sometimes calibration prompt pops up whan it was alredy done manually, but in generall it works. I suggest to add small if - whan dev was already callibrated manually since current wake up, do not fire this...
yes, a bit better, it is working already with sleep off/on but very slow, i always have to wait almost a minute to get this pop-up message (the powermeter is continously active from the start...) so not perfect. (lots of downloadings have higher priority i think and a few background processes and after these are finished then this message pop-up)
