Is anyone experiencing power drops with dual sided power meters? I experience dropouts both indoor and out. I know it's not the power meter since my 520 doesn't have a single dropout during the same conditions. I'm on 6.0 as of now.
Thank you
and is it the latest (2.9) fw for the cranks? Could You check it via Specialized mobile app? Can You share 2 FIT files from a dual recording? (a 520's FIT and a 530's FIT for comparison)
As chance would have it, I have another dual-sided-dual-radio PM (Pioneer). It's not as bad, but I still see drops on the 530 that I don't see on the other head units.
I also see drops with my…
Thanks guys. I’ll update to version 6.2 and see if things improve. During my last test I had so many drops that the data wasn’t useable. Pretty crazy that I now use my older Garmin 520. I filled out the document, and provided files per Garmin’s request at the beta level. Hopefully they figure it out soon.
what is the firmware version in Shimano PM? 4.2.0? I prefer to use only via ANT+ with Garmin devices and pls be sure that the powermeter is not connected via BT to your mobile (to the Shimano app for example, need to disconnect from there) because if both (ANT+ and BT ) are active in the radio part of the R9100-P it can cause decreased signal strength and dropouts.
With a good powermeters ((i have a "few"... and not Shimanos :) ) there are no dropouts with 530/830 series... (that fact that dual or not, doesnt matter, there are master and slave side and the head unit is communicate only with master side, the Shimano 2 sides as i know connected via cable to each other and not via 2.4GHz (ANT+ or BT))
Which one Speci PowerCrank, the 1st or the 2nd GEN already? (the 1st GEN has 2.3 firmware, the 2nd GEN has 4.0 or higher) the 1st was a nighmare with tons of dropouts (the Speci replaced for a 2nd GEN in warranty for my friends), the 2nd one is little bit better but not the same quality as a 4iiii. Not a good powermeter imho....
