Speed sensor not used by EDGE in Indoor Mode
Hi All,
i've just used my new Edge 530 in an indoor session. I have an Elite Direto as trainer and Assioma power meter.
The edge is paired with Assioma and 'should' use Direto as a speed/cadence sensor (i can see it paired correctly)
The problem s that speed showed by edge seems to be calculated on assioma watt and not on direto speed sensor. I ve disconnected the direto speed sensor but edge keeps on showing speed so i m pretty user it is NOT using the trainer speed sensor.
I have also edited wheel circumference as explained by elite but even if the size is dramatically changed (elite suggest to divide actual wheel size by 12.1).
Is there a way to 'force' edge to use the speed sensor to estimate km/h and not watts?
Thanks for the support.
Fabio
Top Replies
    Former Member in reply to Fab4mas +2
    It seems like edge estimates my speed using assioma watts
    should work when the assioma is only power
    • check in the sensor setings for the assioma
    you do not use the direto as a smart tri…
    if assioma is only power should the edge calculate my speed with assioma watt or direto speed sensor?
    "should" ?
    assioma is only power, why "should", your edge is never ever…
    Former Member +1
    hi Fabio,
    did you turn off the assioma cadance sensor in the edge ?
    happy & safe sporting
All Replies
    hi Fabio,
  • Hi, in the edge assioma is only paired as powermeter (i see only 1 "dumbbell" icon ). The only sensor with the cadance icon is the direto (cadance and speed icons).
    0 Former Member in reply to Fab4mas
    what happens when you turn off the direto power sensor
    guess the direto is a combined power/speed sensor ? or are you seeing all separate sensors in the edge
    or do you connect and use the direto as a trainer ?
  • Hi. I have paired the direto only as a speed/cadence sensor. Only assioma is paired as PM. I can see the direto PM icon but it is not active.
    When i start sensor detectin direto appears as two different sensors:
    1) speed/cadence (active in my sessions)
    2) power (Not active in my session).
    you do not use the direto as a smart trianer
    outdoors you only measure speed with GPS
    • turn if off
  • Sorry OnlyTwo i missed something:
    Someone told me that when in 'indoor' mode speed is only calculated with watts even with thousand of speed sensors paired.
    "should" ?
    assioma is only power, why "should", your edge is never ever calculating speed from assioma power
    perhaps via a CIQ app it could
    did you check the settings in assioma sensor
    Slight smile speed is calculated by your irdeto from the watts and send to your edge via a speed sensor
    speed is not send by your assioma to the edge
    how long are you using the irdeto and assioma combined ?
    true if your power meter is working as a combined power/speed sensor
    is it possible to turn speed off with the assioma app ?
    turn it off in the sensor menu from your edge
  • Thx for your answers.
    I use assioma and direto combined since 2018 but assioma was paired with a garmin forerunnner 920 as PM so in garmin connect i was only able to see watts (my indoor rides in garmin connect were all "0 km rides")
    Direto has always been paired with my zwift pc via ant+...
    Now i have and edge 530 so i ve tried to pair it as my forerunner (i didn't care if indoor i see 0 km rides).
    Now i see that edge display a speed so i'm trying to make it more 'realistic' but i see that even if i edit the wheel circumference in direto speed sensor  in edge settings (i tried 174mm as elite suggests) speed doesn t change.
    So if u tellin me that there is no way that edge 'estimates' speed based on watts i ahve to understand if editing the wheel circumference in the sensor is the same thing than editing the circumference in elite app who manage the trainer.
  • direto power sensor is OFF in edge 'sensor' menu. the icon is gray and i can see in the details it is not active.
