New Edge 530 Public Beta 5.68 Now Available
A new Beta software for the Edge 530 has been released. Full change log, instructions, and software for installing the beta can be found in the link below.
Edge 530 (5.68): https://www8.garmin.com/support/agree.jsp?id=14953
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 5.66 to 5.68:
  • Fixed CIQ data field software update migration.
  • Fixed Di2 automatic shifting.
Changes made from version 5.51 to 5.66:
  • Segments:
    Fixed issue with detecting segments that were going in the opposite direction of travel
    Improved segment and ClimbPro UI cooperation
    Fixed issues when approaching a segment embedded in a course and other minor segment UI issues
    Fixed issue where segment virtual partners would claim to be finished almost immediately after starting the segment
  • ClimbPro:
    Improved estimated time to end of a ClimbPro climb
    Fixed ClimbPro page graph drawing
    Fixed issue where disabling 'Pop-up on Climb Approach' would disable ClimbPro completely
  • Improved sensor connectivity
  • Improved automatic FTP detection
  • Added Go Back, Pause, and Go Forward workout step controls to the workout tray
  • Added support for new GPS firmware. Sync your device to update to the new firmware
  • Added option to delete a data field in quick edit mode. Access by pressing and holding a data field on a timer page.
  • Improved grit and flow consistency between Garmin products
  • Improved bike light connection stability
  • Fixed bike alarm not turning off after correct password was entered
  • Fixed radar vehicle drawing temporarily not updating
  • Added a shortcut to the display menu by pressing and holding the Auto Brightness button on the status widget
  • Added a toggle for MTB map theme
  • Improved MTB trail search UI
  • Fixed issue where history line wasn't updated while panning in the map
  • Fixed issue with the number of power zones displayed post ride
  • Fixed dual sided power meter calibration factor reporting only one side
  • Fixed Firstbeat metrics for multiple rides during the same power cycle
  • Fixed Training Effect UI layout
  • Removed unnecessary beeps for notifications that don't need them
  • Fixed timezone map downloads from WiFi
  • Fixed issue with power targets in TCX workouts
  • Made various device stability improvements
  • Actually, just found out that Strava haven’t synced anything other than up hill segments for a while now. (I don’t really use them to notice other than this one)
    Although my segment is slightly downhill over about 3km, my understanding is that as long as the segment is on the device, it should still work?
  • same here. Seems not to work to well in a forest with trees overhanging....
  • here is todays fitfile. GPS accuracy seems to be terrible, especially with overhanging trees...https://we.tl/t-NQEFPP1G5T
  • So I got the old 5.50 file (as I want to go back) from the last roll out and put it into the garmin folder and still says I am on 5.68?
  • I can't go back either. Installation of the old 5.50 fails. I do get the promp if I want to install 5.50, then the bootloader loads and after that 5.68 starts (instead of installing 5.50 firmware).
  • Same and I was like what is happening as I have a F6X and do the betas all of the time and it is not a problem. I tried the 5.50 file that is in this thread and the roll out file.  Funny that the roll out file and this one for 5.50 are different dates.
    I wish I had an older stable firmware so I could try to back date it before 5.50 (looked but not online) that way since it won't go back to 5.50. and keeps looping.  My light network with 5.68 just keeps spinning and disconnects.  GPS is also not stable and for the first time ever on my ride yesterday had a drop out with 5.68 with my speed sensor (full battery).
  • Yeah, this is (one of) the result of the bug what i found months ago in the firmware. Wrong distance values from wrong/duplicated GPS positions and if the user doesnt have speed sensor the speed chart will be so ugly on Strava for example. Btw, You are using smart recording but under the trees (and where somewhy there are duplicated GPS positions) it is recording  with 1 sec recording rate and there is that bug  (that the main code doesnt get GPS position data from GPS chip within 1 sec somewhy and uses the last known position and this duplication makes jaggy speed chart due to the jumping distance values in distance data field ).
  • Thanks for looking into this. Was this bug already reported? (i guess it was ;-) I guess this bug wasn't solved in the 4.5 gps firmware
    I have now switched to 1 sec recording...
  • Is it a faulty unit or do all edge 530 have this problem. This bug makes it a worthless system...
