Device gets stuck during "Transferring to mass storage"
- Device turns off after displaying "Loading courses, workouts, and locations"
- Reset does not work
- Software update cannot be installed because the device is constantly turning off (or couldn't be found while getting stucked)
- Now device gets stuck at "transfer to mass storage"
Any ideas, what I should try next?
  • You could try this
    Force to Mass Storage:
    1. Power the device off
    2. Press and hold the lap button while plugging into USB
    3. Wait 10 to 15 seconds and device should go to mass storage
    0 Former Member in reply to aweatherall
    Hello aweatherall,
    the last status was that the device got stuck at "Transferring to mass storage...". After I pressed the button to turn it off, it immediately restarts and now stucks at "Loading profiles...".
  • You could try intercepting the restart with steps 2 and 3 above.
    If that does not work you might need to try a reset. Again you may need to jump in a step 2 after you force it to power down.
    Non-prompted Non-Vol Clear - Clears NV and deletes all FIT files including Activities, Courses, Workouts.
    1. Turn device off
    2. Hold Lap/Reset and Start/Stop
    3. Press and release the power button
    4. Continue to hold only Lap/Reset and Start/Stop
    5. Release Lap/Reset and Start/Stop when the Garmin Logo is cleared
    6. The unit will restart and clear non-vol
    It's working! Thank you very much! <3
  • Thank you very much !!
