Transfering saved locations from another device
Or you can use something like BaseCamp.
What about transfering locations from Fenix 3 to Edge 530? Doable or will it damage the system?
Should be OK the location format is the same.
I was wondering about, I still have a backup of my Edge510 Locations, I will try that after backing up my edge530 files, the activity file format for the edge530 has changed/updated as an windows exe Application that I use to extract data into a CSV does not work anymore.
I just tried and copied the locations.fit, the file did not have my old locations and subsequently I tried to add location, was able to add a location and name it, when I changed the elevation it kept on showing 46m yet I entered 33, then tried again to change the elevation and it had 00033, I exit, and it still shows 46m I dont see a save button, using back button
