Transfering saved locations from another device
Locations should be transferable. Just copy the locations,fit file from the 820 to the NewFiles folder on the 530.
Or you can use something like BaseCamp.
What about transfering locations from Fenix 3 to Edge 530? Doable or will it damage the system?
Should be OK the location format is the same.
You moved them by copying the locations.fit file from the 520 the Garmin\NewFiles on the 530?
I was wondering about, I still have a backup of my Edge510 Locations, I will try that after backing up my edge530 files, the activity file format for the edge530 has changed/updated as an windows exe Application that I use to extract data into a CSV does not work anymore.
The FIT activity file changed from version 1.0 to 2.0 with support for developer data fields when support for CIQ was added, which the 510 does not support.
I just tried and copied the locations.fit, the file did not have my old locations and subsequently I tried to add location, was able to add a location and name it, when I changed the elevation it kept on showing 46m yet I entered 33, then tried again to change the elevation and it had 00033, I exit, and it still shows 46m I dont see a save button, using back button
thanks I suspected something to that, I recently got aeropod to measure CDA, there is a CIQ for it (I have to copy the file into certain directory, I am assuming that eventually some of that data will be stored as you suggest
