Garmin 530 freezing
My new Garmin 530 has totally frozen  No response from the power button or any others.  I their a reset button or combination of buttons that will restart the device?
  • Try holding the power button down for 20 to 30 seconds
    0 Former Member in reply to aweatherall
    Thank you so much!! That worked.
  • I have some problem after update from 3.5 to 4.1 firmware.
    Device freeze when I have pause.cycling
    Thank you for that, fixed my frozen 530.  Why can't Garmin include that tip in their troubleshooting page? They say hold power for 10 seconds, which did not work for me, and then offer menu-based reset options, which obviously don't work if you cannot access the menus.
    0 Former Member in reply to Former Member
    Same here. I've been using this less than 2 months and it's crashed twice, both times when I'm starting a ride and trying to turn it on. The second time (today) I had to hold it down for much longer than 10 seconds. This shouldn't be happening.
    thanks for your advice - this is my second replacement - not very impressed
    I haven't used my 530 since OCT, Its just been mounted on my bike (using Zwift indoors) thanks to snow, had it off twice to charge second time being last night to get ready for a trip this week...nothing totally blank, best I can get is a grey screen tried all the recommended restart hacks I can find not happy...any suggestions??? Thanks
    Hi, I've got a similar problem. When i charge my 530, it seems to be frozen when i come to use it. I'm assuming that it switches off once charged, but i have to go through a routine of holding operate button for many seconds (10+) before something happens, like a bleep. Then still dead, but if i repeat the 'hold operate' button eventually it comes to life. Seems very unsatisfactory. I will check for update too, but it's not old.  Any ideas? Many thanks.
    Plug in device to power and wait.  Battery might be drained
  • It happened to me twice. First time was before a ride. Second time was during a ride, resulting in an incomplete ride record..
