My edge 530 screen stopped working. I can set the cycle alarm and tricker it with the app on my phone. I can also see that it's turned on in the app. But nothing will show up on the screen.
Same problem, 2 Months old and dark screen.
Found the solution (its a known bug) Just hold power button down till it beeps. Then wait and do a hard reset (power button 10 seconds) This will happen every…
Did you try pressing power 10 seconds?
See here: https://www8.garmin.com/manuals/webhelp/edge530/EN-US/GUID-46A06A7C-1F46-4DBA-B010-DAD7BA6BE59E.html
Also if that does not help it might just be brightness…
I tried this for 10 seconds did not work. How can I get a replacement or my money back. this is the second 530 unit that I have the same problem. I think I will never a garmin ever again.
My first Edge 530 failed and the company replaced it. The second has just similarly failed and I'm not sure I'm even going to bother trying to get them to replacement. My old 520 had its issues, but managed to survive normal use for more than a few months before dying.
Also if that does not help it might just be brightness setting.
As you cannot reset it on device (you cant see anything on the screen you can do a device factory reset)
This means you need to bling step through the process (use some screenshots of the device to work out the click order)
https://www8.garmin.com/manuals/webhelp/edge530/EN-US/GUID-34861F59-6CF2-40AE-8DA4-A484AD8655E8.html
You won't lose any data
