Edge 530 freezing/crashing on course mode
Hi all.
Today I've tried for the first time the "following a course" mode on my edge 530.
Once the course started, I could not switch between screens, it freezed on a map screen with two data fields (distance to next point and time to the next point).
The distance to the next point was always close to 35m, the device "crashed" after getting to this point.
If I clicked enter button, it shown my other data screens just for a second and then it went back to the map screen described above.
I forced a shut down holding power button for 10s, after that, navigation and data screens worked just fine, however the problem happened again after a couple minutes.
Restarted the device again and turned following a course mode  off.
The unit worked as expected for the rest of the ride but I couldn't use the features I wanted (climb pro and turn by turn navigation)
Did anybody experience something similar or have a suggestion?
Thanks
  • What software build are you on?
  • Yesterday the issue happened on 3.50.
    Today I tried another course but on 3.55.
    Exactly the same issue.
    Everything was working fine (navigation to the start of the course and data screens) until the course begun.
  • Is there an err_log.txt in the Garmin\Debugging folder?
  • Yes, actually, There are two:
    err_log;
    err_log_1
    "unit_id":"3999939102",
    "product_name":"Edge 530",
    "software_part_number":"006-B3121-00",
    "ms_since_epoch":1563564994000,
    "system_version":"3.50",
    "build_type":"PRODUCTION",
    "backtrace":" - Error type ( 8 ) err( 8 )",
    "error_cause":"8",
    "proprietary_info":{
        "Commit ID":"4da280b326ad9621b5b6f28ae07c39527fbc3c8a",
        "Time":"2019-7-19 16:36:34",
        "Project Specific":"2019-7-19 16:36:34",
        "Task ID":"0",
        "Task Name":"",
        "R[0]":"00000000",
        "R[1]":"00000000",
        "R[2]":"00000000",
        "R[3]":"00000000",
        "R[4]":"00000000",
        "R[5]":"00000000",
        "R[6]":"00000000",
        "R[7]":"00000000",
        "R[8]":"00000000",
        "R[9]":"00000000",
        "R[10]":"00000000",
        "R[11]":"00000000",
        "R[12]":"00000000",
        "R[13]":"00000000",
        "R[14]":"00000000",
        "R[15]":"00000000",
        "cpsr":"00000000"
    "ms_since_epoch":1563616700000,
    "backtrace":"
    Function Address: 0x60830D12
       Call Address at Function: 0x60830E5A
    Function Address: 0x601F8220
       Call Address at Function: 0x601F85D2
    Function Address: 0x601F91A0
       Call Address at Function: 0x601F91CE
    Function Address: 0x6022BDC8
       Call Address at Function: 0x6022BEA8
    Function Address: 0x605B7234
       Call Address at Function: 0x605B79AA
    Function Address: 0x601F1324
       Call Address at Function: 0x601F17B8
    Function Address: 0x601F1D4C
       Call Address at Function: 0x601F1DB8
    Function Address: 0x601F1DDC
       Call Address at Function: 0x601F1E6C
    "error_cause":"RTL Trap",
        "Time":"2019-7-20 6:58:20",
        "Project Specific":"2019-7-20 6:58:20",
        "CDP_LOG":"05B7EB5,605B7EB5,605B7EB5,605B7EB5,605918C5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605918A5,605B7EB5,605918A5,605B7EB5,605918A5,6055A2F1,605B7EB5,6055A2F1,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,6055A2F1,605B7EB5,605B7EB5,6055A2F1,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,6055A2F1,600DE2A9,605B7EB5,605B7EB5,605B7EB5,600DE2A9,605B7EB5,600DE2A9,605B7EB5,605B7EB5,600DE2A9,605B7EB5,600DE2A9,605B7EB5,600DE2A9,605B7EB5,600DE2A9,605B7EB5,605918B5,605B7EB5,605B0D09,",
        "RTL Error Number":"6E5D8024",
        "Error Message":"D14DE074,00000000,D14DE074,D14DE074,0000000D,00000000,D14DE080,00000009,0000000D,0000000E,00000001,00000004,61ED8AD0,61ED88C0,601F81DF,60830E5A,0000003F",
        "Task Name":"CDP main",
        "Saved SP":"61ED88C0",
        "Saved LR":"601F81DF",
        "Saved PC":"60830E5A",
        "R[0]":"D14DE074",
        "R[1]":"00000000",
        "R[2]":"D14DE074",
        "R[3]":"D14DE074",
        "R[4]":"0000000D",
        "R[5]":"00000000",
        "R[6]":"D14DE080",
        "R[7]":"00000009",
        "R[8]":"0000000D",
        "R[9]":"0000000E",
        "R[10]":"00000001",
        "R[11]":"00000004",
        "R[12]":"61ED8AD0",
        "R[13]":"61ED88C0",
        "R[14]":"601F81DF",
        "R[15]":"60830E5A",
        "cpsr":"0000003F"
    "ms_since_epoch":1563624023000,
    "backtrace":"
        "Time":"2019-7-20 9:0:23",
        "Project Specific":"2019-7-20 9:0:23",
        "CDP_LOG":"05B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605B7EB5,60581FF1,605B7EB5,605B7EB5,605B7EB5,60581FF1,605B7EB5,605B7EB5,605B7EB5,605B7EB5,605918B5,605B7EB5,605B0D09,",
        "Error Message":"D14F5A5C,00000000,D14F5A5C,D14F5A5C,0000000D,00000000,D14F5A68,00000009,0000000D,0000000E,00000001,00000004,61ED8AD0,61ED88C0,601F81DF,60830E5A,0000003F",
        "R[0]":"D14F5A5C",
        "R[1]":"00000000",
        "R[2]":"D14F5A5C",
        "R[3]":"D14F5A5C",
        "R[4]":"0000000D",
        "R[5]":"00000000",
        "R[6]":"D14F5A68",
        "R[7]":"00000009",
        "R[8]":"0000000D",
        "R[9]":"0000000E",
        "R[10]":"00000001",
        "R[11]":"00000004",
        "R[12]":"61ED8AD0",
        "R[13]":"61ED88C0",
        "R[14]":"601F81DF",
        "R[15]":"60830E5A",
        "cpsr":"0000003F"
  • All the entries in the logs that were posted were for build 3.50 and not 3.55.
    If you are able to catch a crash where the log shows a system_version of 3.55 could you post it?
  • , today I recorded another ride and the problem happened again, although a log error has not been created.
    Here is a video of the problem happening during a ride and a photo of the screen the device keeps going back to.
    www.youtube.com/watch
  • Could post the course file you were using?
  • Activity + course.
    During this ride, I had to force a reset and turn following a course mode off.
    Course1.zip
  • My edge 530 froze while navigating a long course- probably 90% of the way through. Powered off/on and it was able to resume. Only issue was that training status/effect/recovery time were off- almost like they only took into account the last 10% of the ride after I resumed. Attaching logs from 3.55 if that helps:
    "unit_id":"3996839270",
    "ms_since_epoch":1563681418000,
    "system_version":"3.55",
    "backtrace":" - Error type ( 2 ) err( 2 )",
    "error_cause":"2",
        "Commit ID":"f36bd8ca6f965fc2ef16328767cfe5737c5c9e94",
        "Time":"2019-7-20 20:56:58",
        "Ram Dump":"N/A",
        "ESht PC":"0x00000000",
        "ESht SP":"0x00000000",
        "Project Specific":"0x00000000",
        "Task ID":"0",
        "Task Name":"",
        "R[0]":"00000000",
        "R[1]":"00000000",
        "R[2]":"00000000",
        "R[3]":"00000000",
        "R[4]":"00000000",
        "R[5]":"00000000",
        "R[6]":"00000000",
        "R[7]":"00000000",
        "R[8]":"00000000",
        "R[9]":"00000000",
        "R[10]":"00000000",
        "R[11]":"00000000",
        "R[12]":"00000000",
        "R[13]":"00000000",
        "R[14]":"00000000",
        "R[15]":"00000000",
        "cpsr":"00000000"
    "ms_since_epoch":1563654320000,
    "backtrace":"
    Function Address: 0x60838F4E
       Call Address at Function: 0x60839096
    Function Address: 0x601FB3FC
       Call Address at Function: 0x601FB7AE
    Function Address: 0x601FC37C
       Call Address at Function: 0x601FC3A8
    Function Address: 0x6022F06C
       Call Address at Function: 0x6022F14C
    Function Address: 0x605C0CCC
       Call Address at Function: 0x605C1448
    Function Address: 0x601F434C
       Call Address at Function: 0x601F47E2
    Function Address: 0x601F4D80
       Call Address at Function: 0x601F4DEC
    Function Address: 0x601F4E10
       Call Address at Function: 0x601F4EA0
        "Time":"2019-7-20 13:25:20",
        "Ram Dump":"2",
        "ESht PC":"0x602D1471",
        "ESht SP":"0x621DE908",
        "Project Specific":"0x621DE908",
        "CDP_LOG":"00E1321,6059C1CD,600E1321,60585005,600E1321,60563709,60563709,6059B6F1,605C1959,6059B6F1,6059B711,60563709,6059C1BD,60563709,605BA351,605BA351,600E1321,605BA351,605BA351,60563709,6059C1BD,60563709,6059B701,60563709,605BA351,605BA351,605BA351,601EA17D,605BA351,601EA17D,605AE865,600E1321,60563709,60563709,6059B6F1,6059B711,60563709,6059C1BD,60563709,6059C1CD,60563709,605C1959,60563709,6041BF61,600E1321,6059C1BD,600E1321,605BA351,605BA351,60563709,605C1959,6059C1BD,605C1959,6059B701,605C1959,605BA351,",
        "Error Message":"D13E5614,00000000,D13E5614,D13E5614,0000000D,00000000,D13E5620,00000009,0000000D,0000000E,00000001,00000004,61ED96E8,61ED94D8,601FB3BB,60839096,0000003F",
        "Saved SP":"61ED94D8",
        "Saved LR":"601FB3BB",
        "Saved PC":"60839096",
        "R[0]":"D13E5614",
        "R[1]":"00000000",
        "R[2]":"D13E5614",
        "R[3]":"D13E5614",
        "R[4]":"0000000D",
        "R[5]":"00000000",
        "R[6]":"D13E5620",
        "R[7]":"00000009",
        "R[8]":"0000000D",
        "R[9]":"0000000E",
        "R[10]":"00000001",
        "R[11]":"00000004",
        "R[12]":"61ED96E8",
        "R[13]":"61ED94D8",
        "R[14]":"601FB3BB",
        "R[15]":"60839096",
        "cpsr":"0000003F"
    "error_cause":"2",
        "Ram Dump":"N/A",
        "Task ID":"0",
        "Task Name":"",
        "R[0]":"00000000",
        "R[1]":"00000000",
        "R[2]":"00000000",
        "R[3]":"00000000",
        "R[4]":"00000000",
        "R[5]":"00000000",
        "R[6]":"00000000",
        "R[7]":"00000000",
        "R[8]":"00000000",
        "R[9]":"00000000",
        "R[10]":"00000000",
        "R[11]":"00000000",
        "R[12]":"00000000",
        "R[13]":"00000000",
        "R[14]":"00000000",
        "R[15]":"00000000",
        "cpsr":"00000000"
    "backtrace":"
        "Ram Dump":"2",
        "R[0]":"D13E5614",
        "R[1]":"00000000",
        "R[2]":"D13E5614",
        "R[3]":"D13E5614",
        "R[4]":"0000000D",
        "R[5]":"00000000",
        "R[6]":"D13E5620",
        "R[7]":"00000009",
        "R[8]":"0000000D",
        "R[9]":"0000000E",
        "R[10]":"00000001",
        "R[11]":"00000004",
        "R[12]":"61ED96E8",
        "R[13]":"61ED94D8",
        "R[14]":"601FB3BB",
        "R[15]":"60839096",
        "cpsr":"0000003F"
