Actual Battery Life
Anyone know the actual battery life. Garmin says 20 hr. with 2 sensors hooked up. So I would assume most have Bluetooth,HR monitor and GPS going while riding. So how many ACTUAL hours do you estimate? THX
    I did a 3hrs 8min ride last Monday, with Power and HR over ANT+. Used a Course for navigation and had the Map screen in front of me for about 40% of the ride. Battery went from 96% to 79% during the ride.
    Would say that the actual battery life should come pretty close to the 20hrs that Garmin is reporting.
    It's realistic. Though that's only using GPS - Galileo or Glonas will eat into your battery life significantly. Mapping will have an effect too. Rendering of the map does take some processing power and rerouting can take a lot.
    Plus, there are battery saving features which you can activate during a ride (most notably turning off the display while keeping all sensors active). With those, you can ride full 24 hours easily.
  • The longest ride I've done with my 830 is 3hr. 42min. and the battery usage was 13% (from 100% to 87%).  I have a Quarq PM, Varia, and Di2 BT.
  • My longest ride so far was 3.5hrs, used 21% (100%-79%) with navigation and 3 sensors connected (ANT+ HR, Cadence, and Speed). Auto brightness turned on and GPS only. Hoping I can make a few tweaks to get 16-17hrs out of it for my next long ride.
    I did an 8h35 ride with navigation, connected to phone via bluetooth and HR + power sensors. Ended up with +50% after the ride.
  • So I have to say the battery life is really impressive, I just finished a 15.5hr ride with 61% remaining. This was with 1s recording, back light only on for 15s after button press, GPS only, full route navigation, and 3 ANT+ sensors. At that rate I would have exceeded the quoted 20hrs by nearly double.
  • Did you have GCM connected too?
  • Unfortunately that has been an issue, only seems to connect if you open GCM after you power on the 530, and I didn't do that before I started the ride, so no GCM connected.
  • Ah!  Nice one though.  I've got 10 hours with GCM on and connected, same set up as yours but on GPS and Galileo.  Ended with 60 %.  Awesome battery!!
