Coming from an edge 1030, which works easily with a Mac. Just plug it in and normal Finder operations work for file transfers.
is that not the case for the 1050? Is there an alternative approach that works well with a Mac?
thanks
thanks
I had the same experience initially. OpenMTP in recent Edge1050 firmware now works fine on Mac. I have a 2019 Intel Mac. No special download links necessary.
Loading courses can be done by importing them into Garmin Connect (web or app) and syncing the Edge 1050 with the Connect app.
Garmin Topo Active maps (replacing the Cycle Maps) can be downloaded from…
https://openmtp.ganeshrvel.com
Available both for apple silicon and intel macs.
mcinner1 On a different topic, we (1040) have one too ;-)
(all the previous 1050 MapTheme topics seem to be closed)
Doesn't work on Intel. Also, a big thank you to the experts in Olathe for removing the hard-to-find download link (from Google's android archive) to the only app that transfers files on macOS. That was worth spending time and money on.
macOS doesn't support MTP because Apple only supports iOS devices natively. I went as far as trying to use a Windows 11 (23H2) VMWare Fusion instance on macOS so I could access the Edge 1050's file system, but I couldn't get that to work either. The only app free app that worked for me was Google's ancient and unmaintained Android File Transfer app. OpenMTP didn't work for me either. MacDroid did work with the Edge 1050, but it's read-only unless you pay for it.
The official response from Garmin is to delete the verified link to the only app from Google that can read the Edge 1050's file system on macOS.
