Hi,
After every restart the brightness gets stucked at a fix value.
I've to switch off the auto brightness button and than turn it on again.
There after the auto function works correct.
Has anybody the same Problem? (V11. 24)
Hi,
It happens only, if you start the 1050 from sleep mode. After a new start of the device auto brightness works. I reported the bug to garmin support. I hope they will fix this very quick. The bug is not fixed with 12.16. It is unfortunate, that with new firmware, new bugs get introduced instead of getting a more reliable device. Currently, the daily suggested workout cannot be removed from homescreen, which is new to 12.16.
Today, I found the following:
Now in winter, I mostly start my ride to work in darkness or low light. Or I put the 1050 onto the handlebar when I am still in the house and start the device there. Therefore until now, I had the impresssion that auto brightness does not work at all, when starting the 1050 from sleep mode. Apparently, this depends on the light conditions, where you start the 1050 in sleep mode.
All this with firmware 12.16.
