Touchscreen freezes 1050
First ride witth the new 1050.
TouchScreen totaly freezes for complete ride. Even when powered of and on several times.
No reaction or whatever  with gloves off.
Taken of the mount in home everything seems te be allright temperature outside was 4 degrees above freezing point
Didnt have this with the 1040 solar, 1030 and the older models.
What tofdo now?
  • quick question so how'd u do a hard reset? TBH, sure wish that day wouldn't come when i must do such move. So far so good from here.... Fingers crossed tone2
  • Press and hold the left hand button until the Garmin turns off and release when you see the Garmin logo
    • Hi I have a screen freeze issue appears to be a recent introduction but not sure when currently on V 13.14. Intermittently does not respond to acknowledgment to pot holes responses etc. Tick box greys out but then freezes. Occasionally if I swipe to change screen there is no response as if the unit is busy. If I wait a while it comes back to life. It has absolutely nothing to do with temperature or wet.
  • Hi All,
    I faced the same case recently, and here's my experience.
    What did I do BEFORE that?
    - I Importeted downloaded from Komoot track (gpx) as distance into garmin.coonect
    - I sent it to 1050 in WIRELESS mode
    - Everything looked well and I started cycling
    - Screen froze after 5-7 min using it, I resrarted it , continued work out  - but nothing has changed. ( Restart - 5 min using - Frozen screen - Repeat).
    What I did next:
    - Hard reset 1050 + Defaul mode
    - I sent the same track to 1050 in WIRED mode
    No frozen screen anymore.
