1050 stuck in reboot loop. I see the Garmin screen, battery % starts to load up some, sometimes will see the home screen for a bit then reboots back to Garmin screen. I can see the file system connected to a Win PC. Help!!
I was able to correct this, Sadly I have to report that Garmin support was absolutely worthless. Total waste of time. After messing with it more I figured out that a profile setting somewhere was corrupt…
Hello all, thanks for your participation here.
The reboot loop smanley described initially was resolved by removing some corrupted activity profiles during a device reset.
If you began experiencing a reboot…
I actually solved it by holding the Lap Button down, connect to a windows PC, wait until it captures „Loader 14.11“ and then you see the Garmin Edge folder. I simply deleted the whole Edge drive folder completely. Then disconnect and restart the Edge. It then works normally after complete new setup process and re-downloading all maps.
I am also experiencing the same issue. Hard powered off my edge 1050 multiple times. It is restarting after about 20 secs so during the loop I went into settings to factory reset the garmin. That did not solve the problem and it is still looping. I have had my gamin edge for only a month.
How annoying. I had to do a factory reset, obviously lost all my screens. What a joke, back to releasing beta software on customers. I pay over $1200 for an edge 1050 and have two watches costing me similar and today all devices had sh_t the bed.
Might be time to make fewer products and perfect the ones you release.
