I have found that the temperature reading of the Edge 1050 is inaccurate by a few degrees Celsius.
Is there any way to calibrate the temperature sensor to adjust for this discrepancy?
Most likely, as in other Edges, the temperature reading is a 'bonus' and just reads the temperature of the pressure sensor, as that sensor needs the temperature of the sensor to compensate for it. Garmin…
As most people have pointed out, the Temp datafield may be just something Garmin threw in. The Edge 1050 manual states that exposure to sunlight, holding the device in your hand, or using the optional…
I just use this https://a.co/d/2BW7ujI the Garmin Tempe
or install windfield and have it display temperature humidity UV etc from weather sources
apps.garmin.com/.../a924715a-2d53-42a1-a8f9-e365bc849840
…Same problem here. When I compare 1050 temperature reading with calibrated thermometer, it's about 5.5C too high at low temps - eg it was 6C in my garage this morning, and after sitting there for half an hour, the 1050 temperature field was indicating 11.5C. That's so inaccurate as to be completely useless - I can make a much better estimate of the temperature myself.
Disappointing to hear.
On my 1030 Plus, having WiFi active increased the heat of the device. Disabling it brought temps near to ambient. Maybe the same on the 1050??
Disabling WiFi has not addressed the issue. The temperature is still inaccurate by about 3°C on average.
No, I have WiFi disabled on the 1050, so that doesn't have any bearing on the inaccuracy of the temperature sensor.
Most likely, as in other Edges, the temperature reading is a 'bonus' and just reads the temperature of the pressure sensor, as that sensor needs the temperature of the sensor to compensate for it. Garmin never put any effort in installing a $1 temperature sensor in a place that is not affected by dissipation of heat from the electronics. So basically you get almost nothing for free.
Then Garmin should list on the box, Bonus inaccurate temperature sensor with every Edge 1050.
>>> the temperature reading is a 'bonus' and just reads the temperature of the pressure sensor<<<
Exactly. If you want more accurate temperature, Garmin will happily sell you a Tempe Sensor.
The Connect IQ app Mapfield, and its two clones, allow you to set one of the data fields displayed to temperature and apply an offset. I've done this and now have a temperature reading there which is pretty accurate. https://apps.garmin.com/apps/30fdcbb5-a0f2-4832-9157-b7dcd81e7a0f
That’s a shame that turning off WiFi has no seeming effect on the 1050. It is noticeable on my 1030 Plus.
I’ve just been for a ride with my 1030 Plus and the average temp matches the local weather stations in the area.
