Garmin Edge 1040 Solar – error message “Sensor is using an open connection”
Hi,
on my Edge 1040 Solar I sometimes get the error message “Sensor is using an open connection.”
When it happens, I have to click it away over 200 times before the screen becomes usable again.
I already tried restarting, re-pairing the sensor, and updating to the latest firmware – no luck so far.
Has anyone else seen this issue or found a fix?
Thanks!
  • I see this message sometimes - not regularly - when ANT+ sensors are going to be connected.
    This is not an error message, but a notice based primarily on EU regulations requiring that “open connections” (everybody can read) be indicated.
    However, this message does not appear repeatedly for me.
  • That happens for me from time to time, maybe once in a month and if you search for it, others have posted that here too. Be lucky that 200 times were enough, some even said the message reappears never ending.
