Garmin IQ Apps Disappear
Running 27.13 and have multiple IQ widgets on 3 different data screens. Frequently after turning on to start a new ride they will just show the IQ icon and I will have to long press and select the IQ app I want in that location.  It happens almost every ride and sometimes even after I start a ride it will again go back to the IQ icon and I'll have to do it again.
  • Can you check this, with power off mode still same. So meaning you don't use a sleep mode at all! Because I stopped using sleep mode for Garmin its buggy.
  • Since my previous post, I’ve been following this thread with interest, as I’m definitely affected by the majority of the other bugs discussed on this forum; it’s just that this particular issue hasn’t manifested for me.
    I see some are pointing the finger at sleep mode, and I’m inclined to agree: I can say is that the last time this happened to me, sleep mode was still enabled on my device. I disabled it about a month ago as a workaround for a different issue (sensor and accessory connectivity after sleep).
    n the meantime, I’ve also updated to firmware 27.14, and still no occurrence of this problem.
    My setup includes multiple Connect IQ fields:
    • Edge MapFields #1 and #2 (McInner)
    • WindField
    • My Bike Radar Traffic
    • SKS Airspy
    • ANT Battery Levels
    It would be great if we had a way to log CIQ apps and device settings, as this may well be app-specific or caused by particular combinations of apps and system settings.
    At this point, it looks like just another manifestation of the broader instabilities in the device’s sleep/wake mechanism.
  • Please can you check if you can still install data fields on device? If yes, then If you can share the folder from device directory Garmin/apps to se maybe some files missing... It my could be bad update process via Bluetooth
