Garmin Edge 1040 fails to reconnect Garmin sensors (especially radar/lights) after waking from sleep
Hello,
I'm encountering a recurring issue with my Garmin Edge 1040. When the device enters sleep mode—either automatically after a timeout or manually (e.g., during a short break to avoid alerts)—it often fails to reconnect to all sensors upon waking.
All my sensors are made by Garmin and fully updated with the latest firmware. This issue has been present since 2022, with some variation in how frequently it reproduces depending on firmware version, but it has never been fully resolved.
The affected sensors vary: sometimes it's speed, cadence, temperature, or power. But the most serious failures involve radar and lights, as they directly impact rider safety. The only indication is a small blinking icon in the top-right corner, which can be easily missed while riding.
Sometimes I can manually reconnect a missing sensor; other times I have to delete and re-add it. Lights are especially problematic—often I need to disable the entire lighting network and hope they reconnect. In some cases, restarting the Edge is the only solution.
I also use a Varia RCT715, and while it's unclear whether the camera resumes recording, that’s less critical. The real problem is that key safety features like radar or the rear light can silently stop working.
If this cannot be fixed completely, at the very least, please consider adding a visible and persistent alert when one or more sensors fail to reconnect after the device wakes from sleep. This would significantly reduce the risk of riding without knowing a safety device is offline.
Thank you,
  • Same erratic behavior. I switch off the 1040 even while riding and relaunch it; either 1 or 2 iteration and the problem disappears! In the last months a new surprising feature came up: battery in charging mode indicates a certain percentage and as unplugged the number and battery duration plunge.
    I always jumped to the latest Garmin version to overcome key failures (starting from Edge 1000 with 2 units failed due to the switch on button, the 1030 lost stability after one time I caught rain) but now there even isn't a more recent model which appears superior to the older ones.
    Hopefully Garmin developers are listening to their devices' users
  • The problem with restarting the Edge is that it interrupts the activity—and that has consequences. It's not a big deal if you're doing a short local loop and can stitch the .fit files together later using Fit File Tools. But when you're at the end of a 250 km ride, it's getting dark, and the rain starts falling, it's incredibly frustrating to lose your entire session data, start a new recording, and just hope that the Edge will take into account at least some of the previous session’s context.
    I’m not looking for workarounds — I expect the underlying issues to be fixed. I didn’t buy these devices from some $5 vendor in Asia. I invested in a system that promised seamless integration and long-term reliability — and I expect proper support even after the purchase.
    I’ve bought all these devices at launch and have been hoping with every firmware update that this would get fixed — but so far, no luck. And now we’re probably getting close to end of support, which makes it even more frustrating.
  • Garmin listening to their device users? Good one…
  • If you restart the Edge you don't need any fit file stitching, the Edge will continue the activity. The problems with restarting are rather that it needs some time and that some IQ datafields will start from zero.
  • Thanks for the reply, Jan but in my experience, things aren't that simple.
    1. If there's an activity in progress, the Edge refuses to shut down. I tested this again just a few days ago. You must end the activity before the device will power off — which completely defeats the purpose if you're trying to quickly restart it during a sensor failure.
    2. In case of a software crash, yes, the activity is preserved, in paused state.
    Last summer, I even tried a long press on the power button to force a shutdown, hoping it would behave like a software crash. Instead. It acted like a "panic button" (who reads the manual Blush). The Edge notified my emergency contact, who immediately tried to call me. Since I was focused on debugging and ignored the call, so i had to explain the whole situation to search and rescue services.
  • Hi 5155879,
    to switch off the Edge 1040 it's enough that after you make a stop with your bike you just STOP the activity, then the display will offer you to SAVE the ride, but you have to disregard the screen and directly press the power off/on button, which will then offer the option in red color to "SWITCH OFF". The Garmin is now OFF, and when you re-start it you will simply find your activity ready again to be saved - DO NOT CONFIRM IT - or reactivated by pressing the START button, which is what you are aiming at (I use regularly this process to switch off the lights connected to the Garmin when I stop during an activity to have a nice Espresso but preventing Radar & Front light from continuing to flash)
  • Similar to what giancarlo said, I do that all the time: Pause the activity with the Start button, use the top left arrow to disregard the saving screen, power off the edge, power it on again and continue the activity with the Start button. That's the way to get all sensors reconnected reliable.
  • Thanks, both @Jan_Mantau and @giancarlo. You're right: if you pause the activity first, the Edge does allow a shutdown, and when powering it back on, the session can be resumed.
    And yes, a cold boot consistently re-establishes sensor connections, making this a valid workaround during intentional stops.
    But this raises a bigger question: what’s the point of “sleep mode” anymore? Honestly, it would be really useful if Garmin allowed disabling sleep mode at the system level. More than once, while getting ready for a ride, and prep took longer than expected, Edge decided to take a nap. As a result, I had to start everything from scratch: shutdown, restart, wait for all sensors, calibrate the power meter, reselect the route, re-enable Power Guide… and by the time I was finally ready, oh look: the pressure in one tire is a bit low, better pump it up quickly before the Edge falls asleep again.
  • I've gotten into the habit of a hard power off after every ride because of this issue.  Otherwise sensors just don't connect (my Favero Assiomas connected over ANT+ being the most frequent offender).
  • For those looking to avoid issues caused by the device entering sleep mode, here are some practical workarounds:
    • The device sleep timer can be disabled per activity profile. This prevents the Edge from going to sleep during longer prep sessions or coffee stops.
      Trade-off:
      –You’ll need to select athe activity immediately after the device finishes booting.
      From what I can tell, the sleep timer is disabled even if the activity hasn’t been started, which is both good and bad:
      it prevents the device from falling asleep during long preparations, but if you forget it with that activity selected, after you finish it, the battery will eventually drain completely.
    • If you want to prevent the device from automatically going to sleep when the activity is paused and you briefly press the power button, you can enable System → Display → Screen Capture.
      With this setting enabled, a short press no longer triggers sleep; instead, it takes a screenshot, effectively blocking unintentional sleep mode activation.
      Trade-offs:
      – You’ll need to delete the accidental screenshots, at some point, and for that, you have to connect the device to a computer. If you’re on macOS, you’ll even need to install third-party apps to do that.
      – You lose the ability to quickly lock or unlock the screen with a short press during an ongoing activity. Instead, it now requires a long press and a manual selection from the menu, which can be difficult in rainy conditions, ironically when this function requires the use of a physical button the most; so this isn’t just a minor inconvenience.
