After upgrade to 24.19. It find the gps log file time was not match the video from GoPro/action 5.
May I know how can fallback the previously fw version such as 21.18?
Please note that a downgrade is equivalent to a factory reset, so you may want to update your 1040's personal settings first.
Here thi version 21.18
Peggatsch, tks you 21.18 fw file, base I my research, it should connect the computer and copy the file to 1040 Garmin folder and restart. It is correct? But I found haven’t falllback process happen. May I know the step for the fallback?
…where can I get the beta program for test?
Open WEB Garmin Connect. On right top there is a clock icon for devices. Chose Edge 1040 and join the Beta program.
WATCH OUT: at the moment the special Beta 24.54 is in roll out. This version will turn your device from mass storage to a MTP device like Edge 1050.
forums.garmin.com/.../public-beta-24-54-and-25-19---20-special-instructions-in-post
forums.garmin.com/beta-program/edge-1040-series/f/announcements/391148/public-beta-24-54-and-25-19---20-special-instructions-in-post
Copy and open this link!
Here are the firmware 24.18 - good luck
Yes JMOFE when you downgrade, the device will be reset to factory settings. But you can save your personal settings before the downgrade and restore them afterwards
If you are interested in the 24.19, the link is below. I don't know which version is better for you
