Hey everyone,
I just had an issue with my Garmin 1040 during charging and I want to know if someone else has experienced the same behavior and if this is a potential problem with the device.
I normally ride around 6-8 hours per week, and the battery lasts for quite a long time, so I typically charge the device after 2 months of use. On Saturday, I went for a ride and encountered some rain (the device got a bit wet), but it worked properly throughout the entire 5-hour ride. When I finished the ride, the battery was at 9%, which was expected.
I got home and dried the device, leaving the charging port open to ensure it was completely dry before charging it. Today, two days later, I plugged it into the charger. After almost 2 hours, I noticed it had charged up to 73%, even reaching 74% while I held the device. Thinking it was taking a long time, I decided to switch to a more powerful charger, but as soon as I disconnected it from the charger, it jumped to 100%.
Has anyone had the same experience? Is this a problem with the device? Should I contact Garmin Service? Or is it a software issue? Could it be caused by the rain? There was no water in the charging port at all, even during the rain, and I left the charging port open at home to ensure it was dry.
