Recovery heart rate
For a few weeks now I have been seeing the Recovery Heart Rate data in the activity statistics, but it always appears with a zero value.
 I record my cycling activities with an edge 1040. Does anything have to be done for this data to appear?
 Greetings
  • Por lo que he leído es una función solo de los relojes de pulsera, que se calcula a partir de la variación del ritmo cardíaco en los 2 minutos posteriores al término de una actividad, pero sigo sin entender porque sale el campo en la estadística de mi Edge 1040 si no la calcula. También  me parece un poco absurdo este campo ya que normalmente las actividades, al menos de bici, se finalizan con un periodo de enfriamiento por lo que el pulso cardíaco va a estar bastante bajo al dar stop a la actividad.
  • thanks for this post and yes i agree, from all research i've done, recovery heart rate is just not possible on the edge devices. this is absurd. so basically garmin is suggesting i should be using my tactix 7 for my bike rides and should never have bought my edge as the watch has every capability of the edge and even more features. ridiculous
  • No debería aparecer el campo en la estadística de actividad de Connect cuando se ha registrado con un edge 1040 o cualquier otro dispositivo no compatible con la frecuencia cardiaca de  recuperación ya que el valor siempre será nulo The field should not appear in the Connect activity statistics when registered with an edge 1040 or any other device that does not support recovery heart rate as the value will always be null
  • The field should not appear in the Connect activity statistics when registered with an edge 1040 or any other device that does not support recovery heart rate as the value will always be null
  • Yeah, kinda ridiculous, a simple calculation of recovery heart rate not available on the 1040.  Or, if it is, I haven't seen it.  Doesn't seem all that complicated to add that option when a ride is completed, just like on the forerunner watches.
