New Edge 1040 Series Public Beta 14.14 Now Available
A new Beta software for the Edge 1040 Series has been released. Full change log, instructions, and software for installing the beta can be found in the link below.
https://www8.garmin.com/support/agree.jsp?id=15990
Notes:
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Change History
Changes made from version 14.13 to 14.14:
  • Fixed crash when connected to external battery
  • Fixed issue related to map zooming
  • Fixed issue returning to previous page after segment completes
  • Fixed issue with Connect IQ apps during activities
  • Fixed issue with scheduled workouts not appearing after sync
  • Fixed issue dismissing turn prompt with tap
  • Added manual compass calibration to test menu
  • Fixed misc bugs and improved stability
Changes made from version 14.12 to 14.13:
  • Updated to Training Status 2.0
  • Fixed issue with Di2/Remote actions going to previous page
  • Fixed Connect IQ issue with getting temperature data
  • Fixed changing data fields on workout data screen
  • Fixed auto lap by position
  • Fixed issues with ebike range
  • Made minor improvement to power calibration UI
  • Fixed various bugs and improved product stability
Changes made from version 12.16 to 14.12:
  • Added support for Ebike Smart Range
  • Added Music Control widget
  • Added support for Intensity Minutes
  • Added support for Fitness Age
  • Added climb markers to elevation graph
  • Added support for the Tempe temperature sensor
  • Added support for Connect IQ glances on the home screen
  • Added Segment Time data field
  • Added support for startup.txt
  • Added support for turning off Daily Suggested Workout on main menu
  • Added support for returning to training loop using Di2/Edge Remote buttons
  • Improved capitalization behavior on the keyboard
  • Improved turn prompt responsiveness
  • Improved auto-pause responsiveness
  • Fixed issues related to Connect IQ
  • Fixed issues related to Real Time Settings
  • Fixed issues related to solar gain reporting
  • Fixed potential freeze with specific map locations in Europe
  • Fixed issues related to map zooming
  • Fixed issue with disabling turn guidance
  • Maybe you joined beta? Slight smile
  • Once again, , you are not being truthful.  This beta update cannot be installed on my Edge 1040 Solar.  This is starting to look deliberate.  What is the intention behind not clarifying which devices this is truly meant to run on?  You must be aware that you portraying a rosier picture than what's actually happening.  What's the benefit of this deception?
  • 14.14
    Garmin 1040 stuck on loading courses screen after I put a .gpx file on it. No way around. Held power button restart. still stuck, plugged in computer- no longer sees it.
    Totally bricked and useless right now and riding in the AM.
    any ideas???
    thanks
  • Try to force your Edge 1040 in USB Mass Storage Mode. Different Edge models use different procedures for that, but when you search with Google you will find several which you can try if one works for the 1040. Maybe Garmin-Matthew can help you out?
    Once in Mass Storage Mode you can try to delete the .gpx file that is causing troubles from ..\Garmin\NewFiles (if it's still there) or from ..\Garmin\Courses (if there it's a .fit file).
  • If you hold power button for 10 seconds and it doesn't restart, I am not sure if there is any other restart procedure. At least I am not aware of any other.
  • Found a bug in 14.14 today: after upgrading fro 14.13 to 14.14, the smart auto drink was no longer working, although it was enabled in the settings. I disabled the setting and re-enabled again. After that, smart drink started working again.
    Mail on this issue sent to Garmin.
  • There is a difference in getting the device in USB mass storage Mode by just connecting it trough USB (and force a restart by pressing the Power button for a long time) and forcing it to do that if the device is unresponsive. Some examples I found after a search:
    https://support.garmin.com/en-US/?faq=PsxSBlFqTL57tN38aI6m29
    How do I put my Garmin Edge into USB mode?
    "Try getting the unit in to mass storage mode by plugging the unit into the usb port. Press and hold lap/reset while pressing the power button for about 5 seconds. The screen will go blank – let up on the power button at that time but keep holding lap/reset. This should force it to mass storage."
    At least Garmin Express needs to be installed on the PC you use for these procedures.
  • It takes a lot longer to force teh 1040 into USB Storage mode. With unit powered off hold down then lap button and then connect the USB cable. You will need to keeping holding the lap button down until it reports it is in USB Mode. This could take up to 1 minute.
  • Been out with 14.14 today for the first time. Absolutely bang on with no issues at all. The grade is still a bit laggy but nothing major.
    Installed on my 1040 solar but had to be done via express as it wouldn't install ota, just kept failing.
  • If i were you I would run like crazy to buy a lottery ticket. If that is not a sign you are a lucky and blessed man today I am not sure what it is!
