New Edge 1040 Series Public Beta 14.12 Now Available
A new Beta software for the Edge 1040 Series has been released. Full change log, instructions, and software for installing the beta can be found in the link below.
https://www8.garmin.com/support/agree.jsp?id=15990
Notes:
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Change History
Changes made from version 12.16 to 14.12:
  • Added support for Ebike Smart Range
  • Added Music Control widget
  • Added support for Intensity Minutes
  • Added support for Fitness Age
  • Added climb markers to elevation graph
  • Added support for the Tempe temperature sensor
  • Added support for Connect IQ glances on the home screen
  • Added Segment Time data field
  • Added support for startup.txt
  • Added support for turning off Daily Suggested Workout on main menu
  • Added support for returning to training loop using Di2/Edge Remote buttons
  • Improved capitalization behavior on the keyboard
  • Improved turn prompt responsiveness
  • Improved auto-pause responsiveness
  • Fixed issues related to Connect IQ
  • Fixed issues related to Real Time Settings
  • Fixed issues related to solar gain reporting
  • Fixed potential freeze with specific map locations in Europe
  • Fixed issues related to map zooming
  • Fixed issue with disabling turn guidance
  • Fixed various bugs and improved product stability
Changes made from version 12.15 to 12.16:
  • Fixed Di2 missing Full Synchro Shift front ring change warning
  • Fixed WiFi password text entry limitation
  • Fixed Right Power Sensor Missing error text
Changes made from version 12.11 to 12.14:
  • Fixed sensor dropouts when using Connect IQ data fields
  • Fixed Power Guide not working for users with high FTP
  • Fixed workout page being removed from the timer loop
  • Fixed segment data screen data fields
  • Improved product stability
  • So we are not supposed to import directly? I will try to create a Strava Route and import to Garmin to see if that makes the trick.
  • It is not so much about how the course is created, but rather to do with the quality of the elevation data contained in the course file and the course point density. Some sites have better elevation data than others.
    Garmin recommends that course creators add a data point approximately even 50 meters to give the best experience using ClimbPro.
  • 1) After 3:30h in a ride, it dropped all ANT+ sensors and never got back. I finished my ride completely blind: no power, no HR, no candence, no Radar.
    Zero dropout until now , 5 hours ride on Saturday , and other before , strange enough
    2) Strava Segments not wokring on this Beta - only show message to Login and never change. Reverting back to 12.16 made it work again
    Working just fine , tested in this morning , maybe you need to re-pair your Strava account with Garmin
    Only think that I realize, but of course make sense , Strava segments does not work while you are in the Workout mode
    Also I don't know how to display map in the segment screen.
    3) Climb is like 20 seconds late (ok, same thing for 12.16). My 830 was perfect on CLimbing. This new 1040 is reallyu a shame..
    Check my feedback and
    The worst part is that reverting to an older version deleted all user data. When we will have an stable version with at least No Dropouts, CIQ, and Climbing working???
    NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
  • What Feedback?
    I did my first ride with 1040 today (previously had 530). The climbs and power guide has around 150m or so delay in display. Makes it otherwise great experience it so good anymore. The GPS is responsive and accurate, expected from a multi band. Hope the future updates will address the lag issue.
  • "It is not so much about how the course is created, but rather to do with the quality of the elevation data contained in the course file and the course point density. Some sites have better elevation data than others.
    Garmin recommends that course creators add a data point approximately even 50 meters to give the best experience using ClimbPro"
    I wrote also some additional  notes , but I will delete it for now.
  • I noticed that with some data fields like Performance Dashboard, Powermaro etc, the temperature is not displayed. Then the WIdget Segment Explore does not work, it is reported to connect to Strava via GC which you have already done also because the Sgment live works. Again with  Strava segments, after having started, traveled and completed a segment, the LIVE result just performed is not displaied at the end.
  • But it works fine with 530 so that should not be an issue on 1040.
  • Same route?
    where and how did you create it?
  • When will the 1040 be added to the official beta testing program?
