A new Beta software for the Edge 1040 has been released. Full change log, instructions, and software for installing the beta can be found in the link below.
Edge 1040 (12.14) https://www8.garmin.com/support/download_details.jsp?id=15990
Notes:
- For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
- Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 12.11 to 12.14:
- Fixed sensor dropouts when using Connect IQ data fields
- Fixed Power Guide not working for users with high FTP
- Fixed workout page being removed from the timer loop
- Fixed segment data screen data fields
- Improved product stability
Installation Instructions
- Connect your Edge 1040 device to your computer using the USB-C cable.
- Download and unzip Edge1040Beta_1214Beta.zip folder.
- Copy the GUPDATE.GCD file from the Edge1040_*** distribution folder to the \Garmin folder of your device's internal storage drive.
- Disconnect your device from the computer, approve the update on the Edge, and wait for the update to finish.
- If you would like to revert to the last public release software, follow the above steps but place the GUPDATE_1211.GCD file in the \Garmin folder. Rename the file to GUPDATE.GCD before disconnecting your device.
NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
