Map orientation
Faulty Features Removed
If it didn't work in the 1030 Plus etc, then the feature may well have been removed in the 1040 :-(
We already know about the Varia Vision, but they have also removed 3D Map Orientation - its no longer listed in the manual.
There is now only North Up or Track Up :-(
P.39
Select an option:
Select North Up to show north at the top of the page.
Select Track Up to show your current direction of travel at the top of the page.
  • Yes, don't know why they did this, kinda stupid
  • It is odd that it is not listed in the manual, but on the device, 3D Orientation is available, and functions perfectly fine.
    Edit: I was still on the 10.6 firmware when I posted this…now on 12.11, it is gone.
  • Are you on build 10.16 and have not yet updated to build 12.11?
  • It didn't work reliably on the 1030 Plus. The road trace kept disappearing and then a diagonal black line would divide the screen. That would happen randomly but very often once per minute or so. I sent GArmin video and screen shots of it happening as have other users :-(
    0 Former Member in reply to der_bierpuncheur
    Its not on my device with the 12.x firmware.
  • It was removed in the 12.x build.
  • I was. I did not realize was not on 12.11. Last night I received a notification about an update, and I accepted it…today, there is no more 3D orientation. I guess it is was removed on 12.11. It worked fine for me before, but now it is not available.
  • It sure would be nice to have back. It is easier to read than a top down view that can get cluttered in urban areas.
  • Did you ever use it on a 1030 Plus? For me the road trace kept vanishing every few minutes and often when that happened it was followed by a black diagonal line across the area view. I reported it back in October (a week after buying it new) last year. Garmin recently told me that there was unlikely to be a fix anytime soon. I then discovered from the manual that it was no longer mentioned for the 1040. I've managed to secure a refund from the shop I brought it from (I have all of the emails from Garmin about other features that won't be fixed). I'm going back to a Garmin 1000 and will wait to see what others bring out later this season.
    After 10 years of Garmin Faults I've totally lost faith in the brand :-( I've been one of their biggest advocates in the past but I just can't any more. It's so sad.... but at the same time quite a relief after 8 months of promises from Garmin that have amounted to nothing.... They offered me 30% discount off a 1040 and we're seeing issues reported already :-(
    I'm sorry to sound negative. I wish all Garmin customers good luck with their products :-)
  • I used a 1030. I had a similar experience with 3D view, and it was annoying. But, I’ll be honest, it wasn’t a big enough deal for me to ditch the Garmin because I really bought it for the performance metrics which Wahoo and Hammerhead do not have. I’ll adapt to the “track up” view. I used it for a 150km route today, and it’s sufficient for what I need.
