Could you provide insights or solutions for the following issue?
When I ride away from home, I often navigate intuitively, covering around 30 to 40 miles. To return home, I typically use saved locations and load my home location. However, I've encountered a problem with my Garmin during this process.
Once I load my home location, the device begins calculating the route percentage, and often, it either fails or takes an unusually long time to complete.
Is there a way to resolve or speed up this process?
Additionally, I've noticed that the further the saved location is from my current position, the less likely it is to load or work properly. Any suggestions for addressing this issue?
