My 1030+ is not recording distance travelled. I have been using the Edge for the past 9 months with no problems until recently.
The device records speed, gradient, and the navigation map work fine so I am at a loss to understand why its not recording distance. The distance issue starts when I power on it remains at ‘0’ throughout ride.
Other -
When the distance problem started I worked through different ideas including removing the speed sensor in order to record directly from the 1030+ GPS
My programmed segments no longer appear on the 1030.
Recently fitted Garmin Vector power meter pedals
Help needed and much appreciated...getting frustrated ;-)
Thanks,
Sean
