Daily suggested workout
This keep on popping up every day despite  i have turned it off. Anyone else who has the same ?
  • Yes i am having the same issue, no matter what i do i cant stop it.
  • I try to send a p.m to the Garmin representative that introduced this s.w
    edit. Was not possible. Will see if i can find a mailadress
  • This keep on popping up every day despite  i have turned it off
    I understand from your post that you have turned this off and the pop up continues, but I am curious if the menu option shows as Enabled or Disabled after a power cycle.
    If you could Disable this once more and then completely power off and power back on, we would need to know if that menu in Daily Suggested Workouts has toggled itself back on. This will help us determine where to go next in resolving this. Also, knowing what software version you are currently running will be helpful as well.
  • Hello, thanks for answer. No , it remains off , even if i toggle on and off.
  • It‘s a well known bug since many months!
    forums.garmin.com/.../1181289
  • Hi, Garmin-Blake,
    I would like to add the Forerunner 745 to this 'list'. I experience the same issue. I enable-disable the Daily Suggested Workouts, then restart the watch, re-enable, re-disable, and then restart it again, and the suggestion is still there. And there is a new suggestion the following day, even though I left it disabled. I experienced it both on the 5.80 firmware and the 6.02 beta (for the Forerunner 745). I have now reverted to the 5.80 and did a factory reset. Also, I noticed on the 6.02 firmware that there were no updated suggestions for the daily workouts. Everything remained the same even though the beta was about improvements in the Daily Suggested Workouts. I apologise that I have a different device than the Edge 1030 here. I thought adding my issue to the list may help you examine the problem and resolve it for all the devices. Thank you for your time and effort.
