Repeating crash while on a course
Did a 100 mile plus ride today that I created in Ride with GPS then uploaded to my Edge 1030+ as a TCX file. The ride crashed repeatedly with the computer restarting over and over again. I didn't lose the ride just some of the time and distance. Usually happened when I was slightly off course. Also, could not get turn-by-turn prompts. Problem clearly began from the beginning of the ride becasue the turn-by-turn was frozen at the first prompt for the entire ride. How can I prevent this from happening again?
  • Look in the Garmin\Debugging folder for a file called err_log.txt. If there is one can you post it here as it might give some clues as to what is going on.
    "unit_id":"3334586539",
    "product_name":"Edge 1030 Plus",
    "software_part_number":"006-B3570-00",
    "ms_since_epoch":1618692147000,
    "system_version":"4.10",
    "build_type":"PRODUCTION",
    "backtrace":"
    Function Address: 0x60455700
       Call Address at Function: 0x6045570E
    Function Address: 0x6044F9E4
       Call Address at Function: 0x6044FAFC
    Function Address: 0x6045037A
       Call Address at Function: 0x6045039E
    Function Address: 0x6028F4C8
       Call Address at Function: 0x6028F520
    Function Address: 0x6028FAD4
       Call Address at Function: 0x6028FB3C
    Function Address: 0x60099488
       Call Address at Function: 0x600996DA
    Function Address: 0x602C0070
       Call Address at Function: 0x602C0126
    "error_cause":"RTL Trap",
    "proprietary_info":{
        "Commit ID":"76669cdddd997b0feef860308a6a9283a161dcf6",
        "Time":"2021-4-17 16:42:27",
        "Project Specific":"2021-4-17 16:42:27",
        "CDP_LOG":"6060B295,6046CFB5,606314C1,606314C1,606314C1,60609E01,606314C1,606155BD,606314C1,60622C05,606314C1,60622C05,606314C1,600E9481,60608C45,600E9481,606314C1,60622C05,606314C1,60622C05,606314C1,600E9481,606314C1,60609B3D,60609BA9,",
        "RTL Error Number":"6E5D8024",
        "Error Message":"131B131A,D04E7448,D04E744C,00000004,131D131C,00000002,00000000,00000001,00000000,00000108,622773D0,622773C4,61FED7F8,61FED6D8,6044FAFD,6045570E,800F003F",
        "Task Name":"ftm main",
        "Saved SP":"61FED6D8",
        "Saved LR":"6044FAFD",
        "Saved PC":"6045570E",
        "R[0]":"131B131A",
        "R[1]":"D04E7448",
        "R[2]":"D04E744C",
        "R[3]":"00000004",
        "R[4]":"131D131C",
        "R[5]":"00000002",
        "R[6]":"00000000",
        "R[7]":"00000001",
        "R[8]":"00000000",
        "R[9]":"00000108",
        "R[10]":"622773D0",
        "R[11]":"622773C4",
        "R[12]":"61FED7F8",
        "R[13]":"61FED6D8",
        "R[14]":"6044FAFD",
        "R[15]":"6045570E",
        "cpsr":"800F003F"
    "ms_since_epoch":1618692285000,
    "backtrace":"
    Function Address: 0x6044F8C4
       Call Address at Function: 0x6044F996
    Function Address: 0x6044FE90
       Call Address at Function: 0x6044FEFA
    Function Address: 0x604502EA
       Call Address at Function: 0x60450302
    Function Address: 0x60450844
       Call Address at Function: 0x604508A8
    Function Address: 0x60A19C88
       Call Address at Function: 0x60A19D1C
    Function Address: 0x60A167EE
       Call Address at Function: 0x60A17300
        "Time":"2021-4-17 16:44:45",
        "Project Specific":"2021-4-17 16:44:45",
        "CDP_LOG":"6060B295,6046CFB5,606314C1,606155BD,606314C1,60609B3D,60609BA9,",
        "Error Message":"D0570DD8,D0023A28,D0023A2C,00000004,131D131C,D0023168,D0023A28,00000000,A0FE983C,D0023168,D0023A34,00000000,627A5C88,A0FE97F8,6044F997,6045570E,8000003F",
        "Task Name":"NAV_bkgd",
        "Saved SP":"A0FE97F8",
        "Saved LR":"6044F997",
        "R[0]":"D0570DD8",
        "R[1]":"D0023A28",
        "R[2]":"D0023A2C",
        "R[3]":"00000004",
        "R[4]":"131D131C",
        "R[5]":"D0023168",
        "R[6]":"D0023A28",
        "R[7]":"00000000",
        "R[8]":"A0FE983C",
        "R[9]":"D0023168",
        "R[10]":"D0023A34",
        "R[11]":"00000000",
        "R[12]":"627A5C88",
        "R[13]":"A0FE97F8",
        "R[14]":"6044F997",
        "R[15]":"6045570E",
        "cpsr":"8000003F"
    "ms_since_epoch":1618692406000,
    "backtrace":"
    Function Address: 0x6045042C
       Call Address at Function: 0x60450558
    Function Address: 0x604509A0
       Call Address at Function: 0x60450A20
    Function Address: 0x6044F370
       Call Address at Function: 0x6044F396
    Function Address: 0x6076B92C
       Call Address at Function: 0x6076B946
    Function Address: 0x6076A114
       Call Address at Function: 0x6076A150
    Function Address: 0x6076A960
       Call Address at Function: 0x6076AA60
    Function Address: 0x6076B10C
       Call Address at Function: 0x6076B31A
    Function Address: 0x6076B3D0
       Call Address at Function: 0x6076B436
    Function Address: 0x60778B58
       Call Address at Function: 0x60778D28
    Function Address: 0x6077A068
       Call Address at Function: 0x6077A1B2
    Function Address: 0x6077A1E8
       Call Address at Function: 0x6077A200
    Function Address: 0x60765518
       Call Address at Function: 0x60765558
    Function Address: 0x6076561C
       Call Address at Function: 0x607656E8
    Function Address: 0x60762518
       Call Address at Function: 0x6076252E
    Function Address: 0x604F10B0
       Call Address at Function: 0x604F11A4
    Function Address: 0x604F18B4
       Call Address at Function: 0x604F18E4
    Function Address: 0x6025F96C
       Call Address at Function: 0x6025FAF8
    Function Address: 0x60228F28
       Call Address at Function: 0x60228F60
    Function Address: 0x6008C4D8
       Call Address at Function: 0x6008CEB0
    Function Address: 0x6026455C
       Call Address at Function: 0x60264640
    Function Address: 0x60254B38
       Call Address at Function: 0x60255460
    Function Address: 0x60643050
       Call Address at Function: 0x6064305A
        "Time":"2021-4-17 16:46:46",
        "Project Specific":"2021-4-17 16:46:46",
        "CDP_LOG":"6060B295,6046CFB5,606314C1,606155BD,606314C1,600E9481,60609B3D,60609BA9,",
        "Error Message":"627A50B9,D05452E8,D05452EC,00000004,131D131C,00000002,00000000,00000001,00000000,00000060,622773D0,622773C4,D061A480,61EF7970,6044FAFD,6045570E,800F003F",
        "Task Name":"CDP main",
        "Saved SP":"61EF7970",
        "R[0]":"627A50B9",
        "R[1]":"D05452E8",
        "R[2]":"D05452EC",
        "R[3]":"00000004",
        "R[4]":"131D131C",
        "R[5]":"00000002",
        "R[6]":"00000000",
        "R[7]":"00000001",
        "R[8]":"00000000",
        "R[9]":"00000060",
        "R[10]":"622773D0",
        "R[11]":"622773C4",
        "R[12]":"D061A480",
        "R[13]":"61EF7970",
        "R[14]":"6044FAFD",
        "R[15]":"6045570E",
        "cpsr":"800F003F"
    "ms_since_epoch":1618692537000,
    "backtrace":"
    Function Address: 0x60450668
       Call Address at Function: 0x60450768
    Function Address: 0x60361AF8
       Call Address at Function: 0x60361B42
    Function Address: 0x600B3CA8
       Call Address at Function: 0x600B7C46
        "Time":"2021-4-17 16:48:57",
        "Project Specific":"2021-4-17 16:48:57",
        "CDP_LOG":"6060B295,6046CFB5,606314C1,606155BD,606314C1,600E9481,600E50C9,60609B3D,60609BA9,",
        "Error Message":"13191318,D05769D0,D05769D4,00000004,131B131A,00000002,00000000,00000001,00000000,000000B8,622773D0,622773C4,214EE2E2,A0FE8998,6044FAFD,6045570E,800D003F",
        "Saved SP":"A0FE8998",
        "R[0]":"13191318",
        "R[1]":"D05769D0",
        "R[2]":"D05769D4",
        "R[3]":"00000004",
        "R[4]":"131B131A",
        "R[5]":"00000002",
        "R[6]":"00000000",
        "R[7]":"00000001",
        "R[8]":"00000000",
        "R[9]":"000000B8",
        "R[10]":"622773D0",
        "R[11]":"622773C4",
        "R[12]":"214EE2E2",
        "R[13]":"A0FE8998",
        "R[14]":"6044FAFD",
        "R[15]":"6045570E",
        "cpsr":"800D003F"
    "ms_since_epoch":1618692661000,
    "backtrace":"
    Function Address: 0x6044F728
       Call Address at Function: 0x6044F762
       Call Address at Function: 0x6044F9A2
        "Time":"2021-4-17 16:51:1",
        "Project Specific":"2021-4-17 16:51:1",
        "CDP_LOG":"6060B295,6046CFB5,606314C1,606155BD,60609B3D,60609BA9,",
        "RTL Error Number":"6E5D806D",
        "Error Message":"A0FE9F68,6044F9A3,D0999720,13191318,00000000",
        "Saved SP":"A0FE97C0",
        "Saved LR":"6044F763",
        "Saved PC":"6044F763",
        "R[0]":"A0FE9F68",
        "R[1]":"6044F9A3",
        "R[2]":"D0999720",
        "R[3]":"13191318",
        "R[4]":"00000000",
        "R[5]":"00000000",
        "R[6]":"00000000",
        "R[7]":"00000000",
        "R[8]":"00000000",
        "R[9]":"00000000",
        "R[10]":"00000000",
        "R[11]":"00000000",
        "R[12]":"00000000",
        "R[13]":"00000000",
        "R[14]":"00000000",
        "R[15]":"00000000",
        "cpsr":"00000000"
  • Oh no See no evil, I know this error from edge 830 :0((, there also it was a rtl_trap error. On edge 830 it happend when i am off course and climp pro was running, turn climp pro to off and try it again.....
  • Is Climb Pro the screen that comes up whenever you approach a rated climb segment? For this ride there were eight segments. I like using it and have never had a problem until this ride. Can try turning it off the next time.
  • Climb pro, is the function who shows you the climbs at your course, it is part of your configuration and you find it as a own data site. Normaly there are no problems, but while routing it seams that the function does make a memory problem on edge 830. If you are off course all climbs must calculated again. I got the problems also on long rides, or when many climbs are on the ride. Have a look on it.
  • Could you attach the course file and the activity from the ride where it crashed.
    What map/version  are you using?
  • https://ridewithgps.com/routes/35716272
    I don't see a way to attach a file and also not sure how to tell which map version I have. This was the US map as I'm in New York City. I've been trying to install a new version of the US map but the install from Garmin Connect doesn't work very well IMO.
  • Sorry, Garmin Express, not Gamin Connect.
  • For the map update, if the problem occurs when Garmin Express tries to update the map on the Edge 1030 Plus after a successfull download, try removing the old version of the map from the Edge 1030 Plus using Manage Maps before running the update process.
  • This doesn't work! Looks like there's an extensive thread about problems updating maps using Garmin Express. I tried removing the 1030+ from Garmin Express and then added it back. Also reinstalled Garmin Express. No luck. Guess I'll have to call Garmin for help. I have a big race coming up and can't have a malfunction on this device.
