Difference course recalculation an route recalculation.
In the 1030plus under activities routing there options course recalculation an route recalculation. What is the difference an what is the effect of the sub menu choices
  • You can try to open one and close the other, my understanding is
    Course recalculation: When you deviate from the course, the return course will be recalculated, and when you do not follow the guided return course, the guided return course will continue to be recalculated until you return to the course
    Route recalculation: It will be recalculated according to the map. When you deviate from the course, you will be guided to return to the course for the first time. When you do not follow the guidance, then the map will take you to the end point. So when I am running the course, I will only Turn on course recalculation and turn off route recalculation
  • I have found this other answer from pjg61 which was very didactic:
    forums.garmin.com/.../course-vs-route-recalculation
