Ride With GPS synch/pin routes.
For all you Edge 1030 Plus people that used to 'pin' and send routes over to your device from Ride With GPS, but can't because there isn't an app in Connect IQ, here is a work around which I think is better.
The Edge 1030 Plus is relatively new and we do not have spec docs, so we have not been able to make a CiQ app for it.  You still have the option for transferring routes wirelessly through the Garmin Courses sync program. This will allow you to transfer routes wirelessly from your Ride with GPS account to Garmin Connect to this device.
To enable Garmin Wireless Courses Sync, follow these steps:
  1. Go to your account Connected Services page https://ridewithgps.com/settings/connected_services
  2. Click "Unlink" on Garmin Connect (see screenshot: https://i.imgur.com/vbQjYcE.png
  3. Click Link again to open the Garmin Connect settings page
  4. Once logged in, also select "Courses" as an option to be enabled for syncing
  5. Finish the setup for re-linking your Garmin Connect account auto sync.  https://ridewithgps.com/help/garmin-courses
Once this is set up, you can Pin any route you want to sync over to your device wirelessly. If you have pinned an item in the past, you will need to re-pin it, as only routes Pinned after this sync has been established will transfer over to your device.
