GSC10 / Edge 500 / Intermittent Speed Readings
Hi, I just recently got an Edge 500 paired with a GSC10. I just did a 40 mile ride, although the speed was very intermittent (sometimes zero and sometimes half my speed). For example, I would be going 20mph and then all of a sudden it would read 8mph, but I didn't change anything. I am pretty sure the total distance read shorter than the ride should have been. I have since tried riding my bike stationary and the speed seems to work fine. I am attaching the .fit file from my latest ride if anyone has any idea what happened.
Thank you, Joshua
    Check the magnet alignment. It should be aligned with the mark on the speed arm with a 2 to 5 mm gap between the magnet and arm.
    It looks like you did not have auto-pause enabled so the Edge did not pause and recorded the entire route. The distance based on GPS data was 41.16. The Edge uses the sensor for distance.
  • Thank you for getting back to me. I have checked the alignment and my wheel magnet looks good. I don't think the issue is with auto-pause because my speed would drop to 0mph while I was riding. My total distance was approximately 36 miles measured by the GSC-10.
    I didn't mean to imply that auto-pause was the issue. Normally the speed dropping to zero triggers auto-pause. Data is not recorded when the Edge pauses. I was just commenting that there were no gaps in your data.
    With the speed dropping out and the distance being short I am fairly confident that the sensor is not triggering consistently. If you can't sort it, removing the wheel magnet will result in GPS data being used for speed/distance. But I would try adjusting the magnet.
  • Thank you for your help. The magnet was too far from the sensor and now it works great.
