GSC10 Data Not Showing on 910xt
I installed a GSC 10 Speed/Pace unit, and on my first ride, I was seeing the results properly on my Forerunner 910xt. Now, the Cadence field will only read "_ _ _ RPM". I've reset the GSC 10 unit, and I see the blinking green light as expected. On the watch, the Sensor Details reads "Connected" and displays the sensor ID. Still no luck on having the Cadence field show a reading. It will occasionally read "0" but never the actual RPM as it did properly on the first ride.
Is there a way to remove the sensor and pair it again? Or other suggestions?
Thanks in advance.
    0 Former Member over 11 years ago
    The light blinks green when speed is triggered and red when cadence is triggered. Are you seeing the red?
    You nailed it. The red light was not flashing. I "rolled" the unit a bit so that the sensor was closer to the crank magnet, and I saw the red cadence counter light up. I verified that the data field on the watch now showed the RPM, which it did.
    I'll keep an eye on the unit's position after a few rides to see if I just bumped it or if I need to tighten it in place. Thanks so much!
    0 Former Member over 4 years ago
    Hi
    I had same problem
    I hard re-booted then set up an account with Garmin Express and synced my 910xt and uploaded new software (3.20 from 2.70)
    after this I paired again the GSC10 and now all working fine - 910 picks up the sensor v. quickly
