Rally 100 Power Sensors and Edge 1000 GPS unit
Am looking for some help please - I have a connectivity issue between a Garmin Edge 1000 and Rally 100 Left (main) and Right ('Upgrade') power meter pedals.
I have had several discussions with Garmin support re this, including sending a video clearly detailing the lack of connectivity, but am getting nowhere so would like to ask...:
Is there anyone successfully using an Edge 1000 unit with paired (dual sided) Rally 100 pedals...?
So far I have...:
  1. Installed and paired the Left Rally 100 Power Meter pedal with no issue - it pairs with the Edge 1000 no problem
  2. Installed the Right Rally 100 Power Metre pedal on the crank.- get a green and a red light initially when turning it
  3. Turned pedals and cranks to wake the power metres up - they both light up momentarily
  4. Accessed the Sensors / Power / Sensor Details menu looking for the "Pair Right Pedal" prompt - it does not exist on my Edge 1000
  5. Tried to add the Right Pedal via "Search All" and the "Power" options in the "Add Sensor" menu option - it does not find it
  6. Swapped Batteries between pedals and done all of the above - Left still works, Right remains invisible - so batteries are all fine
  7. Turned Edge 1000 GPS unit off and on multiple times and repeated all of the above - it does not help - but I've tried the off and on again approach
  8. Disconnected ALL other sensors (Cadence / Heart Rate) and repeated all of the above - no success - still only finds the Left pedal
Does anyone have a solution that does not involve repeating any of the above over and over...?  Does anyone else have a dual sided setup working on an Edge 1000...?
The Edge 1000 RRP (although now discontinued) is £500, the Left pedal £429 and the Right ('upgrade') Pedal is £469.00 - I pretty much paid RRP for all three components making my total spend around the £1 398.00 - thats a lot of money for a one sided power metre option.
Any thoughts would be very welcome, many many thanks,
Tb
  • Hello,
    It sounds like you've tried everything to get your dual-sided Rally 100 pedals working with your Garmin Edge 1000. Unfortunately, it seems like a compatibility issue that might require a firmware update or specific support from Garmin. mypoints login
    I recommend reaching out to Garmin Support again and asking if there are any known issues or updates for this specific setup. You can also check Garmin forums to see if other users have encountered and resolved similar issues.
    Best Regards,
    James Keen
