Garmin, what is the reason for software version 4.0 for being pulled, is there another version being released soon?
I apologize for the confusion I created here. Version 4.00 is now fully available via Garmin Connect Mobile or a compatible Garmin Device.
https://forums.garmin.com/sports-fitness/cycling/f/accessories…
I don’t even want to update it. I just want it to stop asking me every single time I turn on the Garmin.
I just took my sensor off the bike and made sure it was close to the head unit and phone and was the only sensor attached to the head unit. I also took it all away from the bike where none of the other…
They are weirdly silent on this. My Garmin is wanting me to update to 4.0 every single time I pair the sensor, but it can't download it anymore so it eventually fails. This is some bush league software…
Same disconnected problem over here when updating speed sensor from v2.30 to v 4.00 Tried a number of times, no go. Then tried Goughie's bypass of removing the sensor from the bike, away from other sensors. Worked the first time I tried! Maybe the update process gets confused when other speed sensors that also need this update are in the neighborhood of the one that you want to update? Anyway, thanks Goughie!
I have two Speed Sensor 2 (on road and mountain bike).
On one of them (about a month ago), the firmware was updated from version 2.30 to 4.0 (via EDGE 530).
But I still have 2.30 on the second sensor and the newer version is not offered.
Don't know where the problem might be?
Thanks
Mine was stuck on 2.30 with Garmin Connect showing it as up to date, which confused me as lots of others had been receiving the update
The RemoteSW folder on the edge contains things like sensor updates & mine had 3 GCD files in there. I took a punt & renamed all the files; changing the GCD to BCK & synced with Garmin Express, which put another GCD file in there.
When I disconnected the edge, booted & connected the speed sensor, I was prompted me to update,
Thanks for the advice, I'll try it this weekend when I have both Speed sensors with me and let you know.
Have the same issue. Telephone is an iphone 8 if that matters.
As soon as I click on update on the Garmin cycle computer the telephone states: Connection to Garmin lost.
For me this looks like a "must-fail": how can it download an update if the connection to the phone stops as soon as the update starts?
Figured out the solution: The sensor has to be awake. So regularly spinning the wheel (the one with the sensor ;-) helped. The sensor has to be awake at time of starting the update and may not fall asleep before the update is done.
