Hi all,
Can’t find this answer anywhere. I know you can buy a dongle for the X35 and get ANT + to work for Edge models, but does the Ebike remote work on Bluetooth or Ant+ or both?
Thank you in advance,
Steve
Hi all,
Steve
Hi
my girlfriend bought bike with x35 and I was able to connect my Garmin edge 530 with it only there is limit of details to show on data field - from Ebike I had only:
Asist Mode - works only show values 0 - 2 - 4 -7 depends on mode ,
shifting advice - doesn't work - because shifting is manual
Ebike Battery - works fine shipping same value as phone app
travel range - same as above
only on phone app cadence is available but Ebike data filed doest read it form x35 :-(
I have a 2021 Orbea Gain M30 which has ANT+ connectivity built in
I can't seem to get my Edge 520 to find it, when I go to add sensor I do not fid the e bike option in the list...
as far as I know it's on the current SW version 13.20
I have managed to get the Ebike field from JanCapek and it shows the battery % and current assist level
but It would be nice to get the speed sensor displayed on the garmin too, and does it have a cadence sensor built in to the EX35?
remaining miles would be nice too
is there a list of which edge models are compatible with this? I've seem posts saying the 830 and 1030 both work fine, but the 1000 doesn't work. would that maybe mean that the model number has to end in...30 for it to work?
Motion x35 according their web works only through bluetooth
Our X35 system is compatible only with devices with Bluetooth 4.0 or higher. However, there are some devices using specific Bluetooth protocols such as Ant+, Smart… but we do not have connectivity with these specific protocols yet.
waiting for edge 130 plus to check if it will work with x35
after selecting sensor i just search for new one and found ebike
then, after connection it automatically was added new activity profile ebike
on which I have ebike metric data screen
and when I edit my data screen I can add field from ebike category (Assist mode, Shifting advice, eBike battery, travel range)
When I go to
> sensors
>add sensor
I have the following options:
Search all (tried this it says wake up sensor to connect, with the bike switched on I spin the cranks and the motor works but nothing happens on the Garmin, it won't find anything)
and the rest of the options I have are
Cadence, Edge remote, Heart rate, Indoor trainer, Light, Power, Radar, Shifting, Shimano Di2, Speed/Cadence, Speed, Varia Vision, VIRB, Weight Scale
I've tried a few from there and none seem to connect
would be great if someone would be able to confirm if the 520 is even able to connect to the EX35's sensors so I can add the data into my data screens.
or If not, which Garmins will work with it? I think the 130 or 130 plus would do all I need
strange that you do not have ebike in sensor search result
I was using edge 530 and it connect with ebike using bluetooth
Im expecting to get today edge 130plus so will check also with this one - hope there want be a issue
and maybe 520 doesn't have bluetooth or doesn't connect sensors using it ? as ex35 support only bluetooth :-(
