Hi everyone! I had used an EPIX30 and a wired (Cateye) cycle-computer. After every activity, I register both data. Comparing these data from more than 50 activities, I saw that the time registered by EPIX30 is bigger than Cateye in several minutes in every trip, affecting the average speed, example: in a four hours activity cateye shows 22Km/h avrg. and EPIX shows 20.5Km/h avrg. It is important to consider I am using the AUTO-PAUSE function in both computers. After that, I decided to buy a Garmin ANT speed-sensor and installed in my bike. My expectation was, with the wheel sensor and AUTO-PAUSE function active, the EPIX30 would be much more precise than using the GPS data and detects the stop/run moments precisely. My deception now is that I have the same error comparing Cateye vs. EPIX data! The difference between two computers trip time indications is exactly the same with or without ANT speed-sensor. My conclusion is that EPIX30 are not using the wheel sensor data to stop the timer!!! Is there some parameter to config in order to activate this function? What can you say about that?!?! Ps. I am using EPIX30 + ANT speed sensor + Cadence sensor + HR monitor.
