Garmin Forums
Garmin Forums
  • Site
  • User
  • Site
  • Search
  • User
  • Apps & Software
  • Outdoor Recreation
  • Sports & Fitness
  • Pilots
  • Developer
  • Beta Program
  • German Forum
  • More
  • Cancel
  • RE: Enduro E3 Recurring Fast Battery Drain Problem
    Mikkel Ravn
    Mikkel Ravn
    Try disabling pulse oximeter (Spo2).
    I had crazy overnight battery drain on my former watch  (Fenix 7), and disabling that solved it for me.
    • 21 days ago
    • Wearables
    • Enduro 3
  • RE: Massive battery drain after updating to 23.20
    parentoft
    parentoft
    Power off the device.. Wait 1 minute and turn it on again...This has been the fix every single time with massive battery drains.
    • 3 months ago
    • Running/Multisport
    • Forerunner 955 Series
  • Watch face and battery drain?
    Caveman80
    Caveman80
    I wanted to ask you guys about your experiences regarding watch faces and battery consumption:
    There are those that mention when installing that they run in the background and could drain the battery faster as a result.
    I'm currently using the Glance…
    • over 2 years ago
    • Wearables
    • Epix (Gen 2) Series
  • RE: Fenix 7X sapphire solar - Sudden battery drain
    Eren
    Eren
    Yes, I have.
    It does not happen regularly. As I mentioned, It is the second time battery drains like this while the battery is around 30% and not in use.
    • over 3 years ago
    • Wearables
    • fēnix 7 Series
  • RE: Terrible new firmware version 14.10 - Dramatic battery drain
    Garmin-Heath
    Garmin-Heath
    We have identified a possible issue with software version 13.40 for the fenix 5 that can cause additional battery drain to take place. If you are experiencing increased battery drain on your fenix 5, update your software to version 14.20, or later. For…
    • over 5 years ago
    • Outdoor Recreation Archive
    • fēnix 5 Series
  • RE: Venu 2 rapid Battery Drain
    AndRgr
    AndRgr
    This seems to be a problem that occurs more frequently. My Venu 2 is also affected.
    From 100% to 50%, the battery lasts 2-3 days, depending on GPS use. From 50%, the battery is drained much faster, the last 20% are empty within a few hours.
    • over 2 years ago
    • Health & Wellness
    • Venu 2
  • RE: FENIX 6X Pro battery Drain - Firmware 27.00
    Kiligoum
    Kiligoum
    I find this post:
    https://forums.garmin.com/apps-software/mobile-apps-web/f/garmin-connect-web/355158/troubleshooting-guide-for-high-battery-drain
    will try ...
    • 11 months ago
    • Wearables
    • fēnix 6 Series
  • RE: battery drain after 10.18 update
    Garmin-Sierra
    Garmin-Sierra
    Thank you @pf for contacting our Product Support team, and thank you for your patience as we look into this.
    3936458
    Let’s start by power cycling (turning off and then back on) your watch.  If the battery drain persists and if you have any Connect…
    • over 2 years ago
    • Health & Wellness
    • Venu 2 Plus
  • 11.89 Battery Drain after recording a run
    Nick
    Nick
    I still have the issue where my battery drain is normal until I record a run. After the run is saved, my watch loses 1% or more per hour. If I reboot the watch, the drain stops until I record another run. This is getting really annoying!
    Fenix 8 47 amoled…
    • 10 months ago
    • Wearables
    • fēnix 8 Series
  • RE: Battery drain very high since beta upgrade
    59bf723f125544959e3bd11b4cea4fa0
    Battery drain 20% per day with no GPS!   Sleep tracking does not work!  Body battery waaaaay off... perhaps because sleep tracking not working.  This is a hot mess!
    • over 1 year ago
    • Forerunner 165 Series
    • Community Discussion
Copyright © 1996-2023 Garmin Ltd. or its subsidiaries
  • Site Map
  • Terms of Use
  • Privacy
  • Security
