• RE: Battery Drain Problem After SW Update 6.80
    I also observed similar battery drain issue after the 6.80 software update.
  • battery drain too fast
    my fenix6 pro has fast drain battery, i have read about that and understand that is a big problem for many other people like me! i called garmin and wrote to support center and customer service and told about that, no one respond me any correct or logical…
  • Venu 2 Plus - Battery Drain during sleep
    i charged my watch to 100% then went to sleep, around 5-7hrs
    next morning wake up with about 80ish%
    is it common the battery drain so much during sleep?
  • RE: Garmin Fenix 6 Pro Battery Drain 2022
    I'm looking for a solution to my Garmin Fenix ​​6 Pro battery draining extremely fast
    how much days it lasts?
  • RE: Battery not draining!??
    I think it also has to do something with accuracy of battery level indicator. I found out when I have for example around 10% battery, charge it for couple of minutes before going to work so it will charge up to lets say 25%. Then it shows this 25% for…
  • RE: Venu 2 Plus - Sudden Battery Drain
    I'm the OP on this thread and have continued to monitor. Have not experienced the battery drain except for the one time that I reported here. No explanation for the anomaly.
  • Sudden battery drain on Instinct Solar
    Hello
    I've recently noticed that my Instinct Solar suddenly started to loose battery drastically (e.g., 10% during night). Normally, I'd go with 2 weeks without charging, now it has to be done every 3-4 days. The device itself is only half-year old so…
  • RE: 745 battery draining fast after activity
    Hi Brooks, I am on 3.40 on my 745 and I am seeing excessive battery drain.  I just charged to 100% this morning, and after 1 hour Ive already lost 10%.
  • Public Beta 20.04 extrem Battery Drain is back!
    extrem Battery Drain is back and brigthness is set very low, nearly unreadable!
  • RE: Feníx 5X+ after activity battery drain
    It seems that something did not stop processing after you stop the activity. I did a restart on the watch and it seems that the battery drain slower. Could you confirm?
