Sudden battery drain on Instinct Solar
Hello
I've recently noticed that my Instinct Solar suddenly started to loose battery drastically (e.g., 10% during night). Normally, I'd go with 2 weeks without charging, now it has to be done every 3-4 days. The device itself is only half-year old so this is not related to loss of capacity in battery (also this was completely sudden).  Along with this problem, I've noticed that the device displays completely inaccurate solar intensity signal (some background signal of about 10% is noticeable thought the night or indoors). As many others, my device has also a problem with altimeter readings during the activities.
Following actions did not fix battery drain which is the biggest problem to me:
- soft reset
- factory reset
- update to 18.01 beta
I'm currently trying the roll back to 17.0. Do you have any other options if this won't fix battery drain?
Thanks !
  • Try disabling Bluetooth on the watch (option Phone), to test whether it is the culprit, as in some cases.
    Another possibility - there is currently an issue on some other Garmin models with high battery drain when Strava segments are enabled, or when you have any segment longer than 20km among your Favorites. On the GC Mobile app go to Training » Segments and in the top-right menu disable Strava segments if they are on. Then also review all Garmin segments listed on that page, and if there is any segment longer than 20km having a star, un-star it.
  • Bluetooth should is probably not the cause of problem since I noticed same quick battery drain while using power saving mode which automatically disables BT (2-3% drop after 4 hours). I do not use Strava so this cannot be a problem.
    Thanks for answering
  • You can also just let it completely discharge, and then fully recharge. Although it is not the best practice doing it all the time, when you do it occasionally, you won't kill the battery. One of the often discussed possibilities of these rather common issues with battery after a firmware update, is the case when the battery calibration data gets reset during the update. The watch then needs to see the full charging cycle to recalibrate the battery gauge. It is quite well possible that there is in fact no unusual drain at all, just the battery meter does not work accurately.
    I do not use Strava
    Favorited Garmin segments longer than 20 km, according to Garmin Support can cause it too. Though I am not sure whether it is the case with Instinct 2 too, since it probably happens due to the uploading of the segment to the watch, and that feature is not supported by Instinct 2. One never knows though - due to the bug, the GCM app may be trying to push the segments to the watch anyway.
  • I don't use Segments.
    I I tried to roll back software version to 17.0 and 16.5 but it still did not fix the problem. I'll check the complete discharge now.
    Thanks for suggestions.
  • Unfortunately complete discharge did not fix the problem. After two days I have only 20% of battery left (would be probably even lower if not for the 6 hours in sun last day). For now I'm out of ideas how can I fix the problem myself.
  • I had this happen to my Instinct 2 Solar Surf. Garmin said that you should only charge the watch with a very low power charger (not these 30W chargers) and for a max of 2 hours at a time. When I reported this, they connected to my garmin account stats (with my approval) as they can see the detailed USB battery charging history and can detect if the watch has been left charging overnight etc... In summary, use an ancient lo power USB charger and set an alarm to disconnect it after maybe 90 mins max if a full charge was required or less if only 50% discharged.  They ended up replaing mine under guarantee as I hadn't been overcharging the watch but it was very interesting to be able use the garmin connect app to see the watch charging history for myself. If you buy a 2nd hand watch, you've no idea how it's been getting charged. They took a good while to check my charging history and I got th feeling they were looking at every single monthe since the watch was first registered to see my charging behaviour. Hope this helps shed some light on the subject!
