Software version 14.36 has been released to address the fast battery drain issue.
Hi,
I bought Gramin Approach S40 and use to play a round of golf. However, the battery drains quickly and won't last for more than 5 holes!!!
How to fix this? Is there a replacement battery?
I've had 26.93 on my watch for a couple of days now. Updated from 26.92.
Battery drain seems to be very high. Dropped from approximately 16 days estimated remaining at time of update, to 3 days remaining over less than 48 hours. This was with only…
Hello Amber, is there a solution for the Problem with the Battery drain?
I got my new Forerunner 955 and have been using it for almost two weeks now. I noticed twice now that the battery drains faster than expected. Just recently, last night, I charged it to 100% and wore it overnight. I had the backlight turned off and other…
Yesterday started ride with 95% battery. After 160km device turned off showing me 2% left.
During ride I was using:
1. auto-brightness (day was sunny)
2. group-ride screen with navigation, with power and heart rate fields. (navigation uses max details…
I just want to point out that 11.10 probably has a major issue with battery drain and downgrade -> upgrade may not fix it. I was using 11.10 problem-free for several days and the battery drain issue hit last night without warning. You may have fixed your…
after 4 days battery drain at 0.2%/h. I ve done a 3 hours running + music yesterday. Since then, battery drain at 1%/h again. I am too tired of trying to fix the problem so returned for warranty this morning.
It seemed like different watch had different…
I had the case of quick battery drain (about a bar per day without gos activity)
I solved it by doing the following:
-power cycling the device. Not sure if necessary but it can't hurt
- enabling key lock or changing the gps hot key: I found out…
