In the last few weeks the battery drain has been out of control. Draining in a few days. Not sure what has changed since I bought the watch but it started out just fine.
After going to bed last night, my watch has drained itself to near depletion.
i have usually a depletion of 10% pr day of use. But this night it used almost 90% on sleeping.
I have used to the app battery monitor to see my battery use.
I have no activity…
w
With longer/hotter days It was time for me to star back my favorites long (100k) strava segments so I can TT against them. It appears that it triggers excessive battery drain on epix: less than 10hours lifetime :-/ once segment switched off on Garmin…
I've only had the watch for about a month and a half. For the first 3 weeks, the battery drain was normal. Suddenly, after one charge, the battery lasted less than 24 hours with a drain of about 6% per hour. I tried the soft reset that is recommended…
Reason for joining the beta program was the battery drain out of any specs.
Unfortunately there are no notable improvements on the battery drain as mentioned:
https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-955-series/298291…
Tonight the watch has uses only 5% of battery.
However, once I woke up, the alarm has blocked (again) and I need to reboot the watch and in addition, after connected the Bluetooth, the battery falls from 50% to 15% in 20 min...
I repeat: FROM 50% TO 15…
After upgrading to 12.xx, the battery drain is very heavy.Team please look into battery drain. If we need to charge our watch once in 2 days, we would buy other watches next time. Garmin was known for providing, best battery backup.
Hi, since I got my 945 lte last week, I noticed a battery drain issue. The watch last maximum 4 days win 90 minutes running gps only. Is this a hardware issue?
