I had same problem, battery was draining about 15% per hour. I solved that by factory reset.
I just came here to let you know that the battery drain has been solved on my Venu 3s seemingly by either of the following:
1. I recently have changed BACK the wrist setting from right to left. Originally I had started with the left wrist at the beginning…
Yes, I'm on 6.09
Thanks IFK
I have the same problem, probably caused by "weekly activity" 3rd party widget. After uninstalling, the battery drain stopped.
This new update is killing the battery in nearly 30 hours, and I have tried to use different watch faces that all are stock and others from the IQ Connect. All of them seem to drain the battery very quickly, and this all started within the last 2 weeks…
Hi, My battery on my vivoactive4 is draining as ***, I dont know why. Soemtimes its absolutylly OK, but sometimes it drains from 100% to 0% in few hours. No wifi uploads, no oxygen meassuring, no music listening, no workouts. I simply switch the watch…
Since they changed my 265, beta 19.26, to alpha 19.13, the only major use is at night as the main activity monitor, the battery drain is enormous, from 85% to 15% when I go to work, I have to use my grandfather fenix 5x that still works like a rock.
…Since the 26.00 update i have a huge battery drain. My Watch consume 10%/h without any activities. It’s totally useless.
i have tried soft and hard reset without sucess.
What can i do to resolve this ? Is there any possibilities to go back on thé…
The battery drain since SW 5 ist horrible.
So I tired the official tip to RESET the watch.
The battery drain becomes even worser. Now I loose 36% in 10 hours.
The conclusion is very easy:
WHEN YOU DONT FIX IT SOON - WE ALL SWITCH TO APPLE WATCH WHICH…
Hello all,
To participate in this discussion, please visit the main thread:
