• battery drain problem fixed!!!
    after 11 beta series i have abnormal battery drain in any situation. even garmin suport did not know what was problem and many fenix owner around the world have had this problem. to day after update in 18.77 beta , this problem have solved!!
  • Battery drain after 11.10
    OK let’s start another topic till Garmin fix it. Battery drain after 11.10 update is big garbage. After one hour of activity 33% gone. Before only 4% approximately. Tried factory reset, remove XMC file.
    Now it is on Garmin fix it NOW!
  • RE: Massive battery drain
    Well just made another run with same conditions as described before... the only difference is that yesterday i used a structured workout and today i didnt... After 14.26km in 1:04:26 the battery drains from 91% to 69%... its TOO MUCH...
  • Bounce Lte battery drain
    My son got the bounce for Xmas however with LTE on the battery only lasts 8-12 hours. That is with minimal use of the actual watch.
    If airplane mode is on then the battery only drains less than 10% in that same 8-12 hour period. But the watch features…
  • RE: Venu 2S Battery Drain
    All,
    Please see main thread to participate in this discussion:
    Venu 2/2s Battery Drain After sw 9.17
  • Fenix 6x Pro Battery draining
    Started to notice the battery draining way to much even when it is in battery save mode (5% in about 8 hours)
  • Battery drain after a activity
    Hi,
    On my fenix5 is runnning now version 14.73 after I had problems with the v14.20.and the downgrade to v13.30 (the battery was draining even if in the past there was no problems with 13.30)
    Now in 1 week the battery drained only aprox. 30% but yesterday…
  • Backlight Battery Drain
    Since last software upgrade the backlight doesn’t shut off and drains the battery in < than 2 days
  • 13.19 version battery drain!
    After the update last night the battery was drained by 18 percent at night in sleep mode!
