• RE: Battery drain issue
    also had do you prove the battery drain rate to them?
  • 20.50 Battery Drain
    Hi,
    Is there a high battery drain with v20.50? I used to get around 21 days on my watch. Now it only states 15 days (after a full charge).
    Does the battery need changing?
  • Severe Battery Drain
    With no changes to setting I've had major battery drain since updating to 9.33.  When fully charged it shows 13 days and within 3 days I need to charge because of the battery warning.
  • Battery drain
    Since the install to 9.31. My battery is draining a lot faster.
    Checked all systems and the are the same as before. No new watchfaces and use is the same.
    25% drain in half a day?
  • 13.00 battery drain
    Hello, the battery drain problem is still not fixed since 11.xx versions. It’s still a problem on 13.00.
    will we ever see a fix or doesn’t Garmin bother to support older devices anymore?
  • Excessive Battery Drain
    I have noticed battery drain around 0.8%-1% per hour since around Beta 11.20.   I haven't changed any settings since noticing the issue. 7x Solar.  I am only getting 4-5 days of charge.
  • Battery Drain
    Anonymous
    Anonymous
    Battery on Fenix 7X still draining 5% overnight.
  • SV 12.23: Forerunner 255 Series Rapid Battery Drain --- still draining
    I have read the prior threads and saw that Garmin did not find any actionable trends.  Please revisit this issue.  I have been seeing a SIGNICANT battery drain in the past two weeks.  A fully charged battery will drain within one day.  I thought it was a…
  • Battery drain
    Hey everybody,
    The last weeks I had some problem with the battery, it drains much faster the before.
    Anybody else have the same problem, I even shut of the heartrate for saving battery but not even that works.
    New update soon maybe?
  • @joey - battery drain
    Joey - can you confirm/deny that you're seeing battery drain issues on 9.6, in the same vein as the beta fix on the F5 series? No mention of this in the news 9.7 release notes...
