• RE: Battery drain for 25.00 and delayed reactions for key presses
    I noticed an increased battery drain after 25.00 as well. I have Bluetooth, Wifi and Pulse Ox off.
    I tried a soft reset. Battery drain stabilized for a few hours after soft-reset (while I was sleeping), but after activating Bluetooth for a minute to sync…
  • RE: [FW 17.26] battery drain after using GC
    Yes!, I noticed something similar last night. I'm on beta F/W 18.20
    I went from around 70% to 45% in 4 or 5 hours. The battery drain was as if I were doing a GPS activity but actually, I was sleeping (or trying to)
    A few things that might be significant…
  • RE: Battery drain issue in not-ideal conditions (?)
    Having the watch paired with the iR device AND the iR device off can sometimes be the worst case battery drain scenario for the watch. The watch assumes that the device is temporarily out of range - so it tries to reconnect more or less continuously.
  • Battery drain after first full charge Enduro 3
    I did first full charge after 2 week of use getting out of the box. During charge sw was updated to 13.22. Battery level dropped from 100% to 93% after 12 h with battery save mode during 7h sleep. Does the battery usage algorithm need few charges to adapt…
  • Beta v28.00 - massive battery drain
    F6X Sapphire
    100% charged (11p.m.) and not quite a day went down to 72% (next day 2p.m.)! No activities recorded just wearing.
  • RE: 12.25 battery drain / phone connection fixed?
    not fixed, the phone connection is still very active and drains the battery, i have to restart the phone and the watch daily and it does not go away!
  • Drain battery fenix 5s plus
    My Fenix 5S Plus suddenly started draining battery much quicker than before (100% to zero in 24h with no activity and all sensors off). I used to be able to go for a week without charging. I cannot tell what triggered the change, if anything at all. I…
  • importance of setClip function on battery drain
     Hi, I am creating a watch face and looking for saving battery as much as possible.
    After looking at the profiler in the simulator i found out that the draw functions are the heavy ones, which is not surprising.
    I saw that the setClip function is limiting…
  • Drained battery overnight
    Edit: running the beta firmware 3.21
    I charged the watch up last night (approx 7pm) and put it back on my wrist.
    It was still working and showing the time this morning at around 5am when I woke up but it then turned itself off and wouldn't turn back on…
  • 1040 solar battery drain overnight
    I fully charged at 100% the 1040 solar and next day was at 90% . it was turned off and not stand by
