Garmin Forums
Garmin Forums
  • Site
  • User
  • Site
  • Search
  • User
  • Apps & Software
  • Outdoor Recreation
  • Sports & Fitness
  • Pilots
  • Developer
  • Beta Program
  • German Forum
  • More
  • Cancel
  • RE: Forerunner 955 v.15.19 causing increased battery drain
    6249938
    6249938
    I have battery saver on, airplane mode, bluetooth off and my battery drained 65% to 26% with in one night.
    • over 2 years ago
    • Running/Multisport
    • Forerunner 955 Series
  • RE: Watch face without battery draining on Vivoactive 3
    I use the ranger watch face. Battery drain is about .5% per hour with bluetooth and backlight turned off.
    • over 7 years ago
    • Sports & Fitness Archive
    • vivoactive 3 Series
  • HRM-Dual - Fast battery drain
    Sado_Numpsi
    Sado_Numpsi
    I have a problem with HRM-Dual.
    Original Panasonic battery lasted for 7-8 workouts, maybe 20-25 hrs of training. I measured the voltage of the battery after all, and it showed 3,01V.
    After that I put in a new Duracell battery, which lasted almost the…
    • over 1 year ago
    • Accessories & Sensors
  • RE: Random Battery Drain Periods Fenix 8 47mm AMOLED
    dukeskd
    dukeskd
    If it's any consolation, I currently have a 51mm AMOLED and 51mm Solar, both (!) are experiencing battery drains that you've described. I had nights where only 1-2% drained after sleep and others its 6-8%. I thought they fixed the post-activity battery…
    • 11 months ago
    • Wearables
    • fēnix 8 Series
  • RE: SW 4.10: Is your battery drain issue resolved? (Poll)
    pakal
    pakal
    Never had a battery drain issue...
    • over 5 years ago
    • Forerunner 945
  • 10.12 - no HR readings with high battery drain
    Steffen
    Steffen
    Very often in the morning when i turn on my venu3 the hr reading doesn´t start.
    I can see the green lights at the back of the watch but no readings. when i go into the hr-app i can see "measuring" and it take 5-10 sec. until there is hr reading…
    • over 1 year ago
    • Venu 3 Series - Public Beta Bug Report
    • Venu 3 Series - 10.xx Bug Reports
  • 10.12 - no HR reading with high battery drain
    Steffen
    Steffen
    • over 1 year ago
    • Venu 3 Series
    • Community Discussion
  • RE: Battery drain on firmware 10.44 and iOS 16.2?
    SETM
    SETM
    I am running SW 10.44 and iOS 16.1.1 but do not recognize this battery drain. Do you use any third party apps or widget that recently have been updated. If badly written (coded) they can cause battery drain. Try also restart device and see if the hat…
    • over 2 years ago
    • Wearables
    • Epix (Gen 2) Series
  • RE: Battery Drain on Fenix 6X Saphire with firmware 12.20
    Dr Phil
    Dr Phil
    jesperdl said:
    I have battery drain on my new Fenix 6X Saphire which I have had for a couple of weeks.
    I have battery drain too.
    • over 4 years ago
    • Wearables
    • fēnix 6 Series
  • fenix 8 amoled battery drain after upgrade to 12.22
    8217919
    8217919
    serious battery drain with 8% per hour, the fenix8 cannot work as a watch, anyway to downgrade to 11.X?
    • 9 months ago
    • Fenix 8 AMOLED - Fenix 8 Solar - Enduro 3 - Fenix E - Tactix - Quatix 8
Copyright © 1996-2023 Garmin Ltd. or its subsidiaries
  • Site Map
  • Terms of Use
  • Privacy
  • Security
