• BETA 15.06 - BATTERY DRAIN - OPTICAL HRM SENSOR
    Hey people,
    I am also suffering from the battery drain caused by Beta 15.06.
    Fully discharge, recharge, factory reset and soft reset, GE and everything else has been already tried, nothing worked.
    However, I've noticed one strange thing. Yesterday, during…
  • Battery drain on samsung phone, Android 12?
    Since I installed Connect on my new a52s I see an unprecedented battery drain. One night 20% down, the other about 10% which is still double than normal. Tried to hit "force stop" the app in the phone's settings, cleared cache, but it comes back and keeps…
  • RE: Battery Drain During activity (also with no GPS)
    Update:
    I think, I found reason of the battery drain. It's a ANT+ chest HRM, (the old one, not HRM-RUN). I have also HRM ANT+/BT from Decathlon and it makes the same problem with battery drain. Unfortunately I don't have HRM-RUN for testing.
    Anybody…
  • High battery drain after v. 16.00 upgrade
    Is anyone else seeing battery drain issues after upgrading to system software version 16.00? My battery was over 40% after I finished a run workout yesterday. Today I woke up to see it at only 28% (and now down to 26% after a few more hours). Since yesterday…
  • Instinct 2 Solar - Surf Edition battery draining
    Hi,
    I recently purchased a Instinct® 2 Solar - Surf Edition and I'm having issues with battery draining in a few hours. I've done multiple hard and soft resets. Pulse is set to manual, backlight is at 20%, standard face, GPS + Glonass.
    Yesterday…
  • RE: List of who have battery drain problem
    I have indeed found that my battery drains faster than before and obviously after the  update 23.00 . Let say usually I can do 11 days from full battery and now around 9. No change in how I use the watch
  • RE: Vivoactive 4 battery drain after update to 5.80
    Hello AmberD, i did what you said to do, sync than power button for 45 secs. After thar i used third party watchface and battery drain continued...Next day i did soft reset again but now using Garmin watchface and there was no battery drain. Again i tried…
  • Is Battery Drain Fixed In Newer Forerunner 955 Firmwares?
    8 to 12 months ago my Garmin Forerunner 955 started experiencing a 75 - 150% battery drain increase while idle with almost everything off after updating from stock firmware to what was the latest version available at the time.  I tried installing the next…
  • RE: Software Update drains Battery
    Not sure what you want to confirm, but the firmware is all right - it was tested for several months by beta testers (including myself) with no battery issues. You may want to try some tips from the Troubleshooting guide for high battery drain - the vaste…
  • Battery drain issue : Marq 2 System Software 16.22
    Severe Battery Drain issue after updating software of MARQ 2 Aviator watch to version 16.22
    The battery is running out from 100% to 0% in 12 hours.
    All sensors are off.
    No custom Watch face.
    This is very disappointing for a such a premium watch
